Fuel line size?
Discussion in 'Drag Racing' started by scrapper60, Feb 3, 2007.
  1. scrapper60
    scrapper60 MCCI Member
    Alabama
    Is 1/2" overkill and 3/8" sufficient? Race car only.
    Opinions and comments welcomed.
    Thanks
  2. 71gold
    yes...
    ...frank...:bouncy:
  3. ShadowMaster
    ShadowMaster The Bad Guy
    The ShadowLands
    1969 1/2 Maverick
    Very informative answer, Frank. ;)
    "Depends" is the typical answer for your question. Need to know more about your combination and equipment being utilized.
    1/2" line is good if you have enough pump. Hell...we run #12 line from the fuel cell to the pump then #10 from the pump to the regulator. Then, #6 from regulator to carb bowls. We also have a ProStar 500 fuel pump. With a larger line you have to have more pump volume.
    Most mild bracket race application can get by with 1/2" fuel line from cell to regulator. Just have to have enough pump to push the extra volume of fuel in that line.
  4. scrapper60
    Alabama
    Holley Blue Pump
  5. ShadowMaster
    The ShadowLands
    1969 1/2 Maverick
    And??????? Engine? Cam? Carb? Heads? How fast do you intend to go?
  6. wagesofsin
    wagesofsin Official Lurkologist
    sarasota, florida
    74 challenger , 73 'cuda , 72 challenger , 74 barracuda
    was gonna say that! runnin a cell? im using -8 (1/2 ") off the cell to the filter,same to the pump.then ran all new 3/8 tube to the front(all insulated and rubber mounted) then 3/8 line to the reg, and carb. runnin 7 lbs. at idle, wicks up to 9.5 - 10 under extreme load. (and yes, i set the floats accordingly)
  7. 71gold
    ...see... Jerry,
    my answer was ...short and sweet...and will be the same as theirs when they get through talking about it. :yup:
    ...Jerrys' friend Frank...:bouncy:
  8. ShadowMaster
    The ShadowLands
    1969 1/2 Maverick
    Well screw it. Frank has all the answers.
  9. 71gold
    "Opinions and comments welcomed"
    ...was it something i said :huh:
    ...ShadowMasters' friend Frank...:bouncy:
  10. Blown 5.0
    MS.
    1974 Maverick
    If you are going to run new line, why not go with the larger? P.S. a lot of tanks only have a 3/8 suction tube.
