Fuel line ?
Discussion in 'Technical' started by shappa, Mar 31, 2008.
  1. shappa
    shappa Member
    nc
    1972 Grabber 302 c4
    can you replace the fuel line with rubber line instead of metal line and does anyone know why the gas guage reads 3/4 full when its completely full
  2. bmcdaniel
    bmcdaniel Senile Member
    If you mean the entire fuel line, it wouldn't be safe to expose rubber line to the hazards underneath a car and you sure don't wanna run the line inside the car. The gauge may not read correctly for several reasons; sending unit float is absorbing gasoline, sender is going bad, dash panel voltage regulator is going bad, poor connection to dash panel, poor ground at sending unit...
  3. newtoford
    newtoford Member
    New Castle Delaware
    theres not that much fuel pressure in these cars so if you have to replace a section with rubber it'll be ok, just as long as theres no sorrounding hazzards. definatly would only do as much as i absoulty needed tho
