Fuel Pump
Discussion in 'Technical' started by maverick75, May 13, 2005.
  1. maverick75
    I just bought a new fuel pump and it looks small.I have a 75 mav with a V8 the fuel pump it had looks way bigger than the new one i was wondering if the 75 use a different pump then the other years.Since i dont know if its the original engine still.I'm like the 6th owner i know the original was a 2bbl 302 but know it has a 4bbl manifold.Would it make a difference or not.
  2. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    The best way to check is take off the old one and compare. The holes should line up the the lever that goes in the block would be the same length. Some times aftermarket will look differant but they work the same way.
  3. maverick75
    yeah all the holes and sizes match up only just the bowl is smaller would it affect the performance.
  4. Aeon 71maverick
    Aeon 71maverick Member
    Brookings, SD, USA
    Maverick, 1971 2Dr, Green. HighPerf 302 & TCI C4. Interior Black.
    most likly will work just fine. probably different diaphram design, or designed to work on a wider array of applications.:2cents:
    only possible prob would be fuel starve at long-term WOT. you'll know if that happens:eek: , but i doubt it. did ya tell the parts store 4bbl?
    Check fuel pressure to avoid flooding. i had to run a regulator even on a stock fuel pump. my edelbrock seems to like 4 1/2 psi.
    shouldn't be over 6psi as a general rule.
