fuel pump
Discussion in 'General Maverick/Comet' started by lilfarley, Apr 20, 2007.
  1. lilfarley
    lilfarley Chris Comley
    Central City, Iowa
    i am trying to fix my maverick, and it starts up and runs but it dies after a little while, my dad and grandpa say it is the fuel pump. what do you guys think it is if it is a fuel pump ,does anyone know where a good place to get one is?
  2. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    rockauto.com
  3. stmanser
    Davenport, Iowa
    auto zone.. checker.. napa.. pep boys.. advance... o reillys....
  4. don graham
    they're available almost anywhere.:)
  5. PaulS
    Before you replace your pump, check the pressure and flow. A lot of these old Mavericks and Comets have a plastic "sock" type filter over the pick-up tube in the tank. When they get plugged the car will run fine for short periods of time but then it will quit. The problem progresses to the point where the car will eventually not run more than idling. Disconnect the line from the tank to your fuel pump and blow the line out with compressed air. Make sure you have the gas cap off and no more than about half a tank - to prevent a mess. The air will blow the sock off and your car will run fine. An in-line filter (big one) is a necessary thing to collect the crud that plugged the tank filter.
    Paul
  6. Slantsickness
    Slantsickness Member
    Tucson, Az
    1975 2 Dr.
    Yes, yes, yes yes, exactly. I had that same problem with my 250 in the '73 i used to have. Turned out that the "sock" got filled up with this black sludge crap from sitting for 3+ years. Ran fine at idle, but when I went to drive the thing, it would die after 2-3 blocks. Took me 2 weeks to find it. *Check the tank*
