fuel sender wiring
Discussion in 'General Maverick/Comet' started by scs, Mar 15, 2015.
  1. scs
    scs Member
    Prescott wisconsin
    1972 Maverick Grabber
    I've recently "completed" a major overhaul on my wiring. Everything checks out fine :bouncy: except the fuel sender wire has an oscillating 12V - 0V about every second with the ignition switch ON. Is this normal :coco:? It's almost like it is on a flasher, but all the left, right and hazard wires check out fine (and a load is needed to make an old flasher "flash" anyway).
    Worst case is I have only one issue to deal with, much better than multiple wiring issues.
    Thanks!
  2. scs
    scs Member
    Prescott wisconsin
    I think I have answered my question. I found this on a 1970's era ford truck site:
    The fuel sending unit operates off a 5-volt pulse supplied by the instrument panel voltage regulator (IPVR, Fig. 5), so just running a 12V hot wire to the unit won't work, and in fact will fry the sending unit.
    Figure 5
    Amazing this old stuff still works after 40+ years!
  3. Craig Selvey
    Perfectly normal.
