fuel tank insulators
Discussion in 'General Maverick/Comet' started by Cruzin Illusion, Mar 29, 2014.
  1. Cruzin Illusion
    Cruzin Illusion Enigma
    Commerce City, Colorado
    1972 Grabber
    Has anyone while replacing their fuel tank installing rubber fuel tank insulator strips?
    I have seen them on other type of tanks but not on a Maverick. I figure it would help with noise transfer and possible chaffing.
  2. Dave B
    I don't think I've ever seen any, on any of the cars I've owned. Probably not a bad idea in your case, you wouldn't want to wear the paint off between the trunk floor, and the tank.
  3. Craig Selvey
    The tank needs to be grounded in order for the fuel sender to work, so keep that in mind.
  4. 71gold
    I was going to say that...:yup:
  5. Cruzin Illusion
    1972 Grabber
    How would the tank be grounded if the car is painted and the tank painted like I have seen recently? Also do you know how the some of the newer GM tanks work because that is the isolator material I was going to use.
    I have also saw rubber isolator material used in tank straps as well.
  6. mercgt73
    mercgt73 Member
  7. yellow75
    Tillamook Oregon
    On the Falcon I am working on the locking ring for the sending unit has a screw in it to ground the tank sending unit and would also ground the tank, you would just have to put a screw in the frame someplace or run a ground wire to it
  8. Cruzin Illusion
    1972 Grabber
    That is the same type stuff I was looking at. I was planning on running a seperate ground on the sender.
  9. 71gold
    I don't think the tanks were painted from the factory. they would be grounded through the strap bolts to the frame.
    I think the...one wire...sensors use the screw.
  10. Cruzin Illusion
    1972 Grabber
    I am using a 2 wire fuel sending unit in the tank that was built for the car to work with the EFI set up.
    I was going to use the isolator material between the tank and the body.
  11. 71gold
    what is different between...stock and yours...:hmmm:
  12. car-nut
    car-nut Glenn
    conn.
    I think the insulator makes good sense. I plan on doing the same thing. Just run a ground wife like you spoke of and you will be all set.
  13. 71gold
    I noticed that my fuel gauge didn't work after I did my tank mod. I went back and cleaned the ground and all is fine (two wire plug).
  14. Cruzin Illusion
    1972 Grabber
    Here are pictures of the fabricated stainless steel tank for the car, the straps and the other items for the tank.
  15. Dave B
    Very nice! Does the raised part fit thru the factory hole in the trunk floor?
