Fuel Tank Sender
Discussion in 'General Maverick/Comet' started by fmc56, Aug 23, 2005.
  1. fmc56
    fmc56 Member
    Warwick,RI
    1977 Maverick, 1932 Ford Victoria, 1965 Econoline pickup, 1963 Falcon Deluxe Club Wagon, 1963 Falcon Sprint, 1971 SC-360 Hornet, 1972 Gremlin X
    I need to get a new fuel sender for my 77 Maverick. I called AutoKrafters and was told they do not have one for the 77 only the 71-74, but they are on back order with a waiting list of 30!. Will the 71-74 sender fit the 77 tank? Is the only difference the capacity of the tank? If so an inaccurate gauge is better than no gauge at all. I checked with Quanta, who also sell Maverick tanks, but they do not have any senders for them. Is there any other source for the 71-74 senders?
    Thanks, Fred
  2. 71gold
    hi fread,
    i took a '72 and extended the pickup tube to match the '77. how are you checking to come up with the sender is bad? maybe you have overlooked something and the sender is good and it is a float sinking, wire or connection. just a thought...frank...:bouncy:
  3. fmc56
    fmc56 Member
    Warwick,RI
    Frank,
    Thanks. I may be able to find an early one a lot easier.
    Fred
  4. RobertBailey
    RobertBailey MCCI & MCG Member
    Lenoir City, Tennessee
    1972 Grabber Clone,1970 Maverick, 1973 Grabber, 1973 2dr, 1973 Maverick(Parts Car) 2000 Ford SD Truck PowerStroke
  5. Jamie Miles
    Alto, GA
    I've had a few
    Frank makes a good point, as usuall. :)
    To test everything else, I took a piece of wire and shorted the connector together the connets to that fule sender. The gas gauge should go straight up to Full. I had to replace my sending unit and the fule gauge inside the cluster to get mine working again.
  6. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    I called them also. They told me the same thing. A guy here said that evan if I got a new sending unit, it would not work with AutoMeter gauges. I'm think ablout the mustang swap. AutoMeter have gauges that works with mustang senders.
  7. fmc56
    fmc56 Member
    Warwick,RI
    Thanks Robert!
    Fred
