Full Pin-On Hood
Discussion in 'Cosmetic' started by Racer_X, Mar 5, 2012.
  1. Racer_X
    Racer_X Maverick Hugger
    North Carolina
    1974 Maverick (1970 clone)
    dose anyone have any experiance with full pin-on hoods? :hmmm:
  2. b_ryce70Mav
    b_ryce70Mav Member
    Shaw AFB, SC
    Mine is that way now, and its steel. The obvious up side is it is very easy to work in my engine bay with the hood completely removed. The obvious downside is figuring out where to put the hood. Right now since the car is unpainted its not a big deal, I just pop it off and lean it up against the garage, or if I'm in a parking lot against the car. Once its painted that won't be acceptable, and its way too heavy to be trying to gingerly set it on a blanket on the roof as you would with a fiberglass hood. I will probably put my hinges back on before it goes to paint.
  3. blugene
    Unless you have a reason to actually have one I would suggest keep the hinges. Like mentioned, it becomes a hastle trying to put the hood someplace without damaging the corners or paint. AND it could be a two man job.
  4. Racer_X
    North Carolina
    u make a good point, i had in mind to use a race weight hood but it still would be a pain to take off in windy weather
  5. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    I have had alot of cars with lift off hoods..... They have always been light weight fiberglass with dzus fastners to hold then on..... They are not hard to get off by yourself from the side..... I have always glued 4 small sponges towards the 4 corners of the hood just inside the bracing, just lifted it off and set the hood right on the roof (the sponges to protect the paint)..... You do half to be carefull if it gets very windy.....
  6. blugene
    I have seen them blow off the roof. Kinda funny and sad all at the same time.
  7. don graham
    Don't forget to put the pins in. Don't even ask me how I know this one.:biglaugh:
  8. Joe Dirt
    Leave the race car parts for race cars.
    pin on hoods are a pain to deal with on a day to day basis
  9. olerodder
    olerodder Member
    NorCal
    Listen to what everyone has said, unless this is a "Race Only" car stick with the hinges........................it may look neat...........but it is a pain. I have a glass hood with Dzus fasteners, 2 along the back, 3 on each side, and a special latch in front................without the front latch the hood kind of comes up in front (over 100mph) if tied down................don't ask me how I know............I also have 2" foam along the sides and back for a cushion.
    When I travel with the car I have a U-Haul blanket I put on the roof and even in fairly high winds its never blown off.
  10. 1974Mav250I6
    1974Mav250I6 Member
    Tehachapi, CA
    1974 Ford Maverick
    I thought I saw a car with a pin on either side front end, but still on the hinges. I didnt look too bad I guess. Its all about preference, I would imagine. I could go on to imagine fastening two dummy pins on the read near the windshield so it would appear to have all four. But that would fake and to me fake holds a silliness to it. Or, maybe im thinking too much. lol Idk...
