Fun with the choke...
Discussion in 'Technical' started by Doward, Nov 15, 2002.
  1. Doward
    Doward Member
    Hey all, I'm new here. Being the sweet boyfriend I am, I'm rebuilding the 1 bbl on the 250 I6 in my girlfriend's '74 Maverick.
    The guy who had it before here evidently didn't believe in a choke, and massively fubar'd it. It's got a hot pipe that runs to the choke assembly, but it was pinched, and seemingly torn off. I'm trying to locate where the pipe would have went to, from the choke assembly...
    Any help out there for me?
    John
  2. jeremy
    jeremy I build t5's
    Corona, Ca
    That heat pipe should go down to the exhaust manifold, it collects heat off that for the choke.
  3. Doward
    Doward Member
    Do you mean the heat pipe, to the air cleaner assembly? I'll snap pics, brb...
  4. Doward
    Doward Member
    Ok, this is the carb, and I've pointed out the pipe I removed, as it was pinched, and torn off... I need to know where the pipe went.
  5. Doward
    Doward Member
    I'm thinking maybe it went here... but it's clear on the other side of the carb!
  6. 76 Mav
    76 Mav Reformed Camaro junkie
    Cobb County Ga.
    76 Mav , 70 Galaxie ,04 F350,03 Mustang,03 F150
    ummm
    The tube you circled is some sort of emission control device i think ... the heat tube for the choke mounts under the vacume lines that i circled ... I cant find a flashlight that works lol so i cant tell you how it is attached... But yeah it does mount on the opposite side ... the tube runs around the front of the carb
  7. Doward
    Doward Member
    but yet... it seems the pipe should hook up on this side... any ideas?
  8. jeremy
    jeremy I build t5's
    Corona, Ca
    It appears that you have the inline 6. The way that the choke works is that there is a heat sensitive spring inside the choke housing. The exhaust manifolds produce heat that goes through that tube, and into the housing, thus effecting the spring which tightens and opens the choke.
    Basically from the looks of that picture the exhaust manifold is on the left. There is no exhaust manifold on the right side. It would therefore be impossible for the choke tube to come off that side.
    76mav is probably right, it likely bolts to around where he circled, and wraps around to where the port on the carb is.
    Maybe someone with a digital camera and a similar setup can take a picture for you with how it is supposed to be.
  9. Doward
    Doward Member
    Whoops.. .didn't see your post! Ok, I'll check it out tomorrow... thanks!!
  10. 76 Mav
    Cobb County Ga.
    it does
    It mounts in the area under the three vacuum lines that i circled ... I cant see it because i cant find a flashlight but i can feel where it attaches .. It feels like the tubing has a flared end with a nut on it ... there are several bends in the tubing from the point where it attaches to the carb and it works its way around the front of the carb to the passengers side and drops down under those vacume lines
  11. expjames91
    expjames91 Member
    lancaster,CA
    1973 maverick 250L
    mine goes directly into a hole n the side of the manifold..and what 76 seems to be talking about is the exhaust vaccum stuff... but the pipe goes directly from the choke to the side of the manifold. most likely, where you circled..you know, every 250 I've seen looks completely different...i think ford has problems...
  12. 76 Mav
    Cobb County Ga.
    yeah
    Yeah Its probably different according to the year and the emmision devise installed ... On my 76 model the large tube ( Number 1 ) exits at the point shown in the picture then curls around and attaches back to the manifold ... But my heat tube for the choke goes around the front of the carb and mounts to the exaust manifold right under the vacume lines in picture numbered 2 ... But the Tube pictured in number 1 doesnt attach to the exaust it attaches to the thing i have numbered as 3 ...
    wait im getting confused lol :)
  13. expjames91
    expjames91 Member
    lancaster,CA
    1973 maverick 250L
    yeah..lol..my tube goes around the back..i dont have that excess emissions stuff..lol..
  14. MapleMav
    MapleMav Member
    Moose Jaw, SK Canada
    '72 Sprint
    I have the same setup as James on my '71. Heat tube at rear of carb, no extra emissions gear. Had to remove the exhaust manifold because it was split in two, and unfortunately the heat tube got broken in the process of trying to remove it. But I assume that whatever manifold I replace it with will have the tube attached...
  15. expjames91
    expjames91 Member
    lancaster,CA
    1973 maverick 250L
    man though doward..that carb sure is WAAAYYY foward on the engine...mine is dead center on the intake...
