Fuse Box Buss Bar
Discussion in 'General Maverick/Comet' started by rthomas771, Nov 17, 2013.
  1. rthomas771
    I needed a place to tap power for the extra accessories that I added like the trunk light, rear window defogger and auto-dim rearview mirror. I made my own buss bar out of junk I had laying around. I cut a section out of a 1/2" ridged copper tubing with a Dremel and cut-off wheel and then hammered it flat. I cut cardboard from a 12-pack to make a template the correct size to fit the fuse box. With the copper strip and cardboard sandwich in the bench vise, I used a file to get the copper the same size as the cardboard. After a quick test-fit to figure out where to drill holes, I pop-rivet a fuse holder that I removed from an old fuse box to the copper strip. I then drilled a hole for the 1" x 3/16" carriage bolt and jam nuts. The 3-outlet pigtail came from a late 70's/early 80's pickup truck. (I added the eyelet)
    [​IMG] [​IMG] [​IMG] [​IMG]
  2. cactusgrabber
    cactusgrabber Member
    Tempe, Arizona
    72 Grabber
    Very well done. This is a great idea that I can add to my fuse box, for handling some of the extras I will be installing. Looks like the hard to find factory option. Thanks for posting :)
  3. Dave B
    Looks just like the factory part.
  4. bmcdaniel
    bmcdaniel Senile Member
    So, how much current will the wire / ignition switch supplying that conductor handle?
  5. rthomas771
    It theory, it should hold the same amps that any other draw the fuse box can handling. If you want to pull a BIG load you would need to use a relay anyway. You can use the fussed wire to trigger the relay. The pigtail is 14 gauge wire, the buss bar is 0.045" thick. If anything, the fuse clip is the weakest link.
  6. Krazy Comet
    That's a good job...
    By luck I have a orig on a old Torino wiring harness I'll inst on mine...
  7. jodyj272i
    jodyj272i Member
    midville ga
    1970 maverick,1973 comet, 1972 comet
    I saw it in person this past stampede,it looks even better in person, meant to ask u then. where on the F150 did u get the 3 plug harness? By the way,Thank You to all who were there and made my Son & I feel so welcome,we had a great time.
  8. rthomas771
    The speedometer cluster was already gone on the pickup and the plug was in the bottom of the opening.
    It was a pleasure meeting you and your son at the Stampede. Wish we had more time to hang around together. Don't forget to grab a electric trunk lock and switch when you go get the 3-way plug. :tiphat:
  9. jodyj272i
    jodyj272i Member
    midville ga
    Already plan to raid the Pull-a-Part Wednesday while were in Augusta for my physical therapy, btw, u were right on the money bout the voltage regulator on the instrument cluster, Thank you.
  10. 71gold
    Jody, check this out, would like to see you and your Son there...:Handshake...
    http://mmb.maverick.to/showthread.php?t=96047&highlight=christmas
  11. Jamie Miles
    Trucks all the way back to at least 1967 will have that 3 wire pigtail. My '69 F100 Ranger Has one identical, except it's black. Behind the instrument cluster on the left side.
  12. rthomas771
    That's good to know the earlier trucks have them too. My '60 Falcon has the same plug also but the gauge wire is a lot smaller.
