Fuse box dilemma
Discussion in 'Technical' started by 71Jetta, Sep 13, 2008.
  1. 71Jetta
    71Jetta Member
    Oregon
    1971 Maverick V8, 2001 Jetta VR6
    Here we go... another step towards making my maverick run (only taking a lot longer then i had hoped).
    So, My fuse box is in pretty bad shape (Rusted to the point that some of the fuses are even rusted). And one fuse spot (a middle one, 20amp) has fallen out and taken the connector with it.
    Anyone have a recommendation on how to fix this? Is there a place i can buy a new box(i've looked around.. all i see is covers or add ons. But the box appears to be un-boltable..I think)?
    (Sorry for those i haven't replied to lately, Been spending a lot of time searching for a new job, haven't been on here much)
  2. Bryant
    the box unbolts from the fire wall, but is attaced to the dash harness. you probly either need to remove that whole harness and fuse block and get one a good one from a member on here. i know that 72 is different from 73. i dont know if older ones are different. you might be able to pull it down and some how rebuild it.
  3. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    IMO you should just buy a universal Ford wiring harness from Painless Wiring....New fuse box and new wiring.....My car caught fire as a result of old wiring....just a thought;)
  4. 71gold
    my Ron Francis wireing kit
    FORD POWERED EXPRESS WIRING Buy - XP-67
    COMPLETE WIRING SYSTEM
    We supply you with connectors for stock Ford , ididit, Flaming River and other brands of steering columns. Wiring is included for the complete car - starter, one-wire alternator (external alternators add VR-99), points, Dura-Spark and aftermarket distributors. It will also wire the full gauge set including tach and neutral safety switches; and for all lighting needed for most safety inspections including Hi and Lo beams, indicator lights, parking, turn signal, brake and third brake light. The EXPRESS has been simplified over earlier kits to speed installation and facilitate trouble-shooting. We use HIGH TEMPERATURE fire resistant wire that is color-coded to the panel, each with the circuit clearly and legibly printed, supplemented by our famous COLOR CODED INSTRUCTIONS. An isolated cooling fan relay with wiring and a quality headlight switch are standard. A unique serial number for each kit allows us to provide technical assistance to you and any subsequent owner.
    Our newest custom wiring system is built specifically for your vehicle with all the connectors and wiring necessary to drive it, pass inspection, and be able to add accessories as you see fit, now and in the future. We have included the cooling fan relay & wiring. This is due to the fact that more and more customers are using electric fans. Now you can have everything centrally located for a cleaner installation! We've also added a Multi-Connection Battery Junction Block to reduce the number of wires going to the starter for all those add-ons in your custom application.
    *Clear Coated, Polished Stainless Steel Finish
    *18 Circuits on 16 Fuses
    *4 Select-A-Fuses
    *Faster Installation with New Style Terminal Block
    *Cooling Fan Relay & Wiring Included
    *Only the Best Quality Wire and Terminals
    *Proper Size Heavy Wire for Each Circuit
    *Handles 100 Amp Alternators
    *Serial Number
    *Includes the Proper Connectors & Terminals
    *Clear, Simple, Color Coded Instructions
    The Express is a direct replacement for all previous Ron Francis Wiring kits. It has a very similar bag structure to the past models. All variations of alternator, distributor and steering column are available. Along with the cooling fan wiring and the Multi-Connection Battery Juntion Block, it has 16 fuses, 4 of them select-a-circuit, for complete flexibility in building it your way. The 3-digit part number series harnesses indicate engine manufacturer. Some foreign applications are available.
    Dash ignition and floor dimmer switch users update to new reliable switches. Order RON FRANCIS WIRING Part # SW-37.
    If you have an externally regulated alternator we recommend ordering the Voltage Regulator (Order RON FRANCIS WIRING Part # VR-88).
    the only optional wire was the...backup wire...
    the guy that installed it had all the factory wire ends...with them he kept all the stock plugs.
    i ordered the...flat connectors...for the tail ligh sockets...this way the new wire ran into the socket and the new ends were installed...(no splices).(y)
    headlight plugs were done the same way.
    my AOD has a saftey/neutral switch...w/backup lights. AOD/OD lockout
    intermitten wipers... lights on/buzzer...power plug.
    we are installing the dome light w/map lights now.
    ...:thumbs2:...
