fuse question...
Discussion in 'Technical' started by 71gold, Jul 14, 2012.
  1. 71gold
    I have power on all the fuses except one...the one I need...:D
    all the other fuses on the switched on mode have power, this one doesn't. the fuse is good...Ron Francis...16 fuse panel...:huh:
    how could this be????
    http://www.ronfrancis.com/prodinfo.asp?number=XP-67
  2. Bryant
    sounds like the fuse panel has a problem with the wiring hook ups in side it. i would take it apart and see if maybe a wire came off or a bad connection is in there.
  3. mav1970
    I would imagine you are talking about not having any power to the input side of the fuse in the panel?
    About 12 years ago, I worked for Altec Industries wiring up bucket trucks and some of the large fuse panels, that we used, would have spares that were dead - if you needed to power them to be used, you installed a small copper jumper inside the box on the buss bar. :hmmm::huh:
  4. 71gold
    ...looks like this thing may get its power from a toggle switch...
    Effie said if the A/C quits on the road...not a problem...but ain't leaving home with it not working...(y)
  5. mav1970
    Is it feasible to just jump an input power wire off of the switched common lead to light the dead fuse that you need?
  6. pegleg1858
    pegleg1858 Member
    kentucky
    69 1/2 maverick
    Check your power supplyfrom the battery pos. You may have lost it there. Jumping around in a fuse box sounds like a good way to get in bigger trouble or even burn a car down.
  7. mav1970
    That why I figured the phrase "is it feasible" got me off the liability hook :rofl2:
  8. 71gold
    maybe, but to loose one leg in the middle of the panel seems strange...:yup:
  9. Earl Branham
    Lugoff, SC
    Welll.....does it get power from a toggle switch, and does it help to get it going?
  10. 71gold
    don't know yet...trying to decide what end to power up...the motor or the switch...:yup:
  11. mercgt73
    Does that panel have a built in ignition kill switch? Maybe it is supposed to kill a number of the fuses?
  12. 71gold
    don't think so...it's just one fuse...:Handshake
