Fuse requirements for headlights?
Discussion in 'Technical' started by canuck222, May 22, 2020.
  1. canuck222
    canuck222 vroom, vroom... Supporting Member
    Woodstock, ON
    '73 Mercury Comet, 302, Auto
    I am looking to install a Painless Cirkit Boss Auxiliary fuse block in the engine bay between the shock tower and the washer fluid tank and have some questions.
    1) Based on my markups below, what size fuse is required for...
    • The high beam circuit - Having trouble finding information on amperage for an oem headlight
    • The low beam circuit
    • The horn circuit - does it even make sense to run horn power from this fuse block to a relay?
    2) Are the other fuse sizes reasonable? What have I messed up? Note max rating for each circuit on this block is 20 amp.
  2. Krazy Comet
    DGD likes this.
  3. mojo
    I have 15A fuses in my under hood aux panel on hi & low beams, never an issue in 6 or 7 years of operation. I'm using upgrade halogen replacement beams -- fuses and new beams made nice improvement in night vision.
    DGD likes this.
