GAAA! angry fact time
Discussion in 'General Maverick/Comet' started by ptpdub, Jul 21, 2013.
  1. ptpdub
    ptpdub Member
    canada Sk.
    no c4 in the entire world has ever not leaked ATF. everywhere. NONE!
    there, now I feel better. let the rebuking begin.
  2. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Not true, mine doesn't leak oil, it leaks trans fluid:D
  3. ptpdub
    ptpdub Member
    canada Sk.
    oops, perhaps I should fix that.
  4. Dave B
    I had a AOD that leaked, my new one doesn't.
  5. scooper77515
    There is a youtube video describing how to stop those leaks. Supposedly, it was a Ford bad design, which did not let the seals in the shifter seal all the way.
  6. ptpdub
    ptpdub Member
    canada Sk.
    I am searching now. Do you have a link?
  7. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    The C4's I build don't seem to leak.... :huh:
  8. scooper77515
    Hmmm. Can't find it now.
    There was a blueprint drawing showing that the bolt/shaft was too long, and if you shaved some material off some place or another, when you put it all back together, it was leak proof.
    But you have to pull the valve body out, pull out the shaft, and do some actual machining to it to make the o-ring and/or seal fit where it is supposed to.
    If anyone finds this fix, please post it up here. I would love to do the fix on mine, and stop the only leak on my car...
  9. Rayell
    Rayell Member
    Lizella, GA
    1975 Maverick, 1963 Falcon Ranchero, 1993 Ford Ranger, 2000 Ford Taurus
    My 75 set up for over thirty years. I have driven it for more than 300 miles since I got it running. The transmission does not leak. The PS is a different story.
  10. ptpdub
    ptpdub Member
    canada Sk.
    I have the perfect fix for that. I ripped mine off. no leaks now!
  11. Mercurycruizers
    Venetia, PA
    The C-4 Paul S built for me doesn't leak....
