gas adjust shocks? steering componets?
Discussion in 'Technical' started by JC13, Jun 29, 2002.
  1. JC13
    JC13 Loyal To The Maverick
    Colorado
    1973 Maverick
    First?....are gas adjust shocks, are they adjustable? if so how is this done.
    second?....there is a clicking from my steering....not in the gear box but rather the idler arm. what parts should I get to rebuild my steering? Thanks, john c.
  2. K. Merring
    K. Merring Regular
    Easton,Pa.
    73 Comet GT
    John, I don't know for sure how the gas adjust works as there are several makes. They could adjust by twisting the shaft or one make has a knob on the outside. I think that this type of shock is a little overkill and is for fine tuning unless that is what your looking for.
    On the steering noise, I would pin down what it is in order to know what to do about it. First place I would check is the mounting bolts through the frame into the steering box for being loose or broken, then interference of the linkage with some other part of the under carrage. There could be a problem with the control arm bushings being worn and causing some noise when turning the steering. Good luck.
  3. JC13
    Colorado
    1973 Maverick
    thanks
    the steering linkage is all in need of attention. Do you have any good sources to send me too? I have thoes KYB shocks in front and they seem too stiff. I just put them on and never adjusted anything.
  4. K. Merring
    K. Merring Regular
    Easton,Pa.
    73 Comet GT
    In general, the outer tie rod ends , the idle arm on the right side and ball joints are found at most auto supply stores. The upper and lower arms and bushings, spring pads and mounts can be obtained from a Mustang supply by ordering parts for the 70 to 73 model. They are the same parts. Auto Crafters has all the parts in there catalog page 23. Look at www.autokrafters.com.
    If you are going to do the job, be awhere that the springs are under pressure. A spring compressor and caution, in order to be safe. Study what needs to be done before starting to work.
