gas caps
Discussion in 'General Maverick/Comet' started by Retta Ranch, Apr 1, 2008.
  1. Retta Ranch
    Retta Ranch Member
    Grandview, Texas
    1973 Maverick 2-door, 1971 Maverick 2-door. 1962 Galaxy 500
    will the 70 gas cap fit a 73? silly question, I know. Humor me :)
    Rhonda
  2. rayzorsharp
    Yes it will. All Maverick and Comet gas caps will fit one another
  3. Retta Ranch
    Retta Ranch Member
    Grandview, Texas
    thanks, I thought so
    Rhonda
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    It will physically fit but the 70 caps are different from the 73 due to fuel system venting.
  5. Ford Guy
    Ford Guy Member
    Pinnacle, NC
    1973 Grabber
    Would a cap from an older Mustang fit, because I've seen some aftermarket billet ones that I would like to put on my Mav.
  6. rayzorsharp
    Yes, they will fit. Like Allen said above, they may or may not be vented but they will twist on the Maverick neck just fine.
  7. Craig Selvey
    Not all Maverick caps will twist on just fine. Some caps have more "ears" than others. Some caps, once installed, stick out farther than others or are too close to the body. Some would be so close to the body that they will not go on at all. bottom line....it is almost a guessing game when it comes to gas caps, but the later year cars used the caps with 4 "ears", while the early cars used the caps with only 2 "ears". If you find a cap you like....but it won't fit....don't give up. All you need to do is find the correct gas tank "neck" and it will fit on your car.
  8. rayzorsharp
    Or get a bigger hammer :cool:
