Gas gauge is not working
Discussion in 'Technical' started by 1974fordmaverik, Jan 23, 2010.
  1. 1974fordmaverik
    1974fordmaverik Member
    huber heights Ohio
    74 Maverick
    i was wondering what is wrong with my gas gauge. I dont know if it is a bad ground or if the sending unit in the tank is bad. I have a 74 maverick 302 v8. thank you
  2. 302-72-mav
    302-72-mav Member
    sactown CA
    take the sending unit out of the tank and inspect it and you can flush the tank at the same time ?
  3. 1974fordmaverik
    huber heights Ohio
    74 Maverick
    is the sending unit hard to get to?
  4. 302-72-mav
    302-72-mav Member
    sactown CA
    in my 72 it was under the car Driver side on the gas tank just a twist and it pop's out then spills gas everywhere so have something to catch it in :rofl2:or just take the hose off before and drain it
  5. 1974fordmaverik
    huber heights Ohio
    74 Maverick
    thank you for your help
  6. 302-72-mav
    302-72-mav Member
    sactown CA
    any time:dance: :D :burnout:
  7. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    First thing you need to due is to check gauge and wiring ..
    to due this unplug plug at sending unit take a small jumper wire ( with key in the on position ) jump across the two wires in the plug at sending unit IF the gauge goes to full the wiring and gauge and cvr (cluster voltage regulator ) is OK your sending is bad .. maybe just a bad float ..
    Jay
  8. Dave B
    If you do pull the sender, drain as much gas as you can, you'll be amazed how much gas will come pouring out. Plus, it's GAS expensive and highly flammable!
  9. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    Is the gauge completely non-functioning, or just wildly inaccurate? It might just be the voltage regulator in your instrument cluster.
  10. 1974fordmaverik
    huber heights Ohio
    74 Maverick
    the gauge is stuck on empty and it does not move
  11. Lingwendil
    Lingwendil Member
    Turlock, California
    Bump for Justice, I have the same issue with mine. If it is the regulator in the dash, can it be repaired, or do I have to just replace it?
  12. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    If it's stuck on empty, pull the plug at the sending unit on the tank and jump the two sockets as suggested. If it goes to full with the ignition key in the run position, the sending unit is bad. I just replaced mine on my 74 with one from AutoKrafters. It's stainless steel, so rust will not be a problem. About $80. I bought mine off of eBay from them with free shipping. An electric fuel pump will empty the tank, but still be prepared in case it doesn't. And use the new "O" ring or it will leak! Don't ask me how I know!
  13. rickm
    rickm Member
    Owosso Mi
    I just had the same deal and I pulled the sending unit and the float was full of gas. New float coming today. Oh when you have the unit out hook up all your wires and move the float arm by hand to see if the unit is working.
  14. sam03rc
    sam03rc Member
    gates county, nc
    1972 maverick 302 C4
    had the same thing happen with mine i didnt even have a float on the sending unit pull it and see man when you drain the tank keep an eye out for rust in the bottom on the tank too mine was terrible replaced the whole tank
