gas gauge ohms resistance
Discussion in 'Technical' started by actionrpm, Jun 27, 2009.
  1. actionrpm
    actionrpm Differential specialist
    western pa.
    '70 mav. '40 Ford Pickup '72 Bronco '06 SuperDuty V-10
    I'm trying to get my factory fuel gauge to work right with my sender in my fuel cell,does anyone know the resistance in the volt reg. for the gauges in a stock '70 Mav.?I don't really want to pull the Tach,Shift light and Cluster out right now,I have a buddy that thinks he can change the resitance to make it work right,if someone knows what it is,Thanks
  2. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    The range of resistance is 10 ohm = full .... 78 ohm = empty.
  3. PaulS
    That is the resistance of the sender - not the gauge or constant voltage regulator.
    If the fuel cell came with a C3bby sender then you are going to have to change the sender to a Ford unit or get a matching gauge.
