Gas pumps and Brake lights
Discussion in 'Technical' started by mcaleb, Oct 4, 2012.
  1. mcaleb
    mcaleb Member
    Patterson, California
    1971 mercury comet 302
    Has anyone had problems with the gas pump nozzle not sealing correctly to the filler? Every time I go to the gas station I end up leaving a small puddle of precious fuel behind...
    Also, this is may seem like a stupid question, but I cant seem to get the bulbs out of the sockets for the brake lights, is there some special trick or are they just stuck in there?
  2. rthomas771
    I switch to a '75-'77 "No Lead" filler neck with the trap door on my '74. I can now go full blast with the nozzle. The Nozzle's in GA are different than the CA nozzle's...we don't have the spring loaded accordion style rubber boot, matter of fact some don't have a spring around the nozzle.
    To remove the bulb...push it in the socket then turn. Don't push too hard or the bulb could break
  3. mcaleb
    mcaleb Member
    Thanks I'll try that. How much do the filler necks go for? Will they work with the stock tank?
    I managed to get one of the bulbs out doing that, but the other one looks different, and it doesnt want to push in or rotate. We gave it quite a bit of pressure but we didnt want to break it. Any ideas?
  4. 71gold
    does it look like it has been replaced with one of the push/pull type?
  5. 71gold
    they will work...:thumbs2:
    run an ad in the...parts wanted section...and see what they are offered for...:Handshake
  6. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
    can you put one of them into a 70 tank that drops in the trunk?
  7. 71gold
    I don't see why not...:thumbs2:
  8. vvr210
    vvr210 Member
    Vista,CA
    How hard is it to take out that filler neck?
  9. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
    Not sure about the other tanks, but for a 70 it is very easy. Screws on the outside of the tail panel. The tube goes right thru there and into the top of the tank.
  10. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    I always use a short piece of heater hose that's slightly smaller than the bulb instead of my fingers for this exact reason.
  11. mcaleb
    mcaleb Member
    I got the new filler neck and I took the old one out. When I tried to put the new one in I found that it is to long. Could I cut it or do you guys not recommend that?
  12. Craig Selvey
    Is the new one longer than the old one? 1971-1977 should all be the same length.
  13. mcaleb
    mcaleb Member
    The newer one is longer. It's from a 74 I believe. The original is from a 71.
  14. Craig Selvey
    How much longer is it?
  15. mcaleb
    mcaleb Member
    About 2 inches or so longer.
