Gas tank interior is yellow!
Discussion in 'General Maverick/Comet' started by Rev Ron, Jan 27, 2012.
  1. Rev Ron
    Rev Ron Member
    Dalzell, SC
    Comet GT
    Maverick and Comet lovers, I am restoring a 73 Comet GT. I took off the gas tank to inspect it and it is yellow/gold on the inside! Is this some sort of sealer that you may know of? Also, the outside of the tank has a thick, black sealant that was brushed on. It appears there were coins placed all over the tank, then the sealant was brushed on. Talk to me... what's up with the coins? Someone has also installed a drain plug, so it has been worked on before. I know there are some guys out there who know about these things...
  2. injectedmav
    injectedmav Member
    Georgia
  3. Rev Ron
    Rev Ron Member
    Dalzell, SC
    Comet GT
    Not sure
    I am not sure it is the stuff? It says it is gray when it dries out. My tank is definitely bright yellow/ gold... maybe there is something else someone knows about... and how about the coins?
  4. Dave B
    The coins plug the holes.
  5. Acornridgeman
    Wisconsin
    I have had tank sealers in the past that were very yellow in color.
  6. Craig Selvey
    I have had tanks fixed....and they use coins to fix the holes.
  7. Sopp
    Sopp Member
    Eau Claire, WI
    1976 Comet 4 door, 1972 Comet 2 door
    Do they braze the coins on? Silver solder? Epoxy? I'm older than dirt and have never ran across coins on a gas tank. Need more info.
    Sopp
  8. Craig Selvey
    I have no idea. I seem to recall it was mostly pennys and maybe some nickles.
  9. John Holden
    John Holden Member
    NJ
    It could be a different brand of sealer called Cream or Kreme but I forget how they spell it.
