gas tank leak
Discussion in 'General Maverick/Comet' started by smegnl, Jul 26, 2010.
  1. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Well my gas tank leak is back. Thats all, just complaining.
  2. 302-72-mav
    302-72-mav Member
    sactown CA
    what did you use
  3. Mad Goon
    Mad Goon Scaring the Hondas
    Redondo Beach, California
    Bubblegum and some band aids should do the trick
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Mine was leaking at the MCG Gathering. Jeff Phillips brought over some gas cans on Thursday morning and we drained the tank. Used emery cloth to clean things up and put some tooth in it. Used the 2 part epoxy repair and let it setup for most of the day. Filled it up that night and it has been holding so far.
  5. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    cleaned it with brake parts cleaner. Then a gas tank repair stick/epoxy thing that you mix then apply. The guy before me had a screw in there to plug it up, so Its a good size hole. I left the screw in. Im thinking about getting a rubber washer. Tighten the screw, then put the stick/epoxy stuff around the screw.
  6. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    In case you were sitting on the edge of your seat, I think I got the leak fixed. Turned out to NOT be the same leak with the screw in it. There was a pinhole next to it that was slowly leaking. Epoxied it up and checked it hrs later looks ok. :thumbs2: Will check it tomorrow and spray on some undercoating if its still good.
  7. mojo
    Eventually ur going to have to replace that tank. A lot of guys use a new Mustang tank. Check the tech articles if u have'nt already.
  8. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Yeah I know, once I get some more major things done, I hope to snag a 70 tank and send it out to get redone. Or pull mine and send it out over the winter.
  9. predfan2001
    Why redo a 70 Mustang tank? You can get a new tank 65-68, sender and hardware from Ky Mustang for just over $100.00. It will require some fabing.
    I just think gas tanks aren't something you should band-aid....if there's one hole, there will be more. I plan on leaving mine in the garage and no way I want to worry about springing a leak.
  10. simple man
    simple man Member
    Bunnell,Florida
    Napa auto parts has an epoxy kit made just for fuel tanks. I used it 2yrs ago on our hunting jeep and it's still working! If I remember right it was $14.00.:)
  11. Earl Branham
    Lugoff, SC
    No one repops the '70 tank, and the Mustang one won't fit. Look carefully before you buy a Mustang tank.
  12. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    I wasnt going to redo a mustang tank. I want to find a 70 Maverick tank and send it out to get redone and put in the car. From everything I have read no one makes a new drop in tank for a 70 maverick.
  13. predfan2001
    Well if you hang on awhile and keep looking....I'm sure you can find a good tank. Mine was very usable with some work I'm sure, but as I said...I'd just feel better with a new Mustang tank. My dad re-did a Farmall Super A once and had the tank cleaned and coated and had nothing but problems so I didn't want to go that route, though a car might be a different story since a car like the Maverick has a pick up screen.
