Gas Tank Sending Unit Gasket
Discussion in 'General Maverick/Comet' started by BigDog41364, Nov 8, 2019.
  1. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    What type of gasket is used in the gas sending unit. I cant tell in the photos if its an -O- ring or a flat round gasket. I noticed yesterday there was a small amount of gas under the back of the Maverick, I was hoping it was just a loose line, it wasn't. Its leaking around the sending unit. i wiggled it around a little now its leaking a lot. I'm supposes to meet up with some high school buds tonight to show the car off. My old maverick was a big part of our high school years. I was hoping i could just pull the sending unit and put a new -O- ring behind it and be good to go.
  2. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    It is a large o-ring that is squared on the edges.
  3. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    can I use a -O- ring for a temporary fix?
  4. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    believe it or not, my local ford dealer had them in stock. Was less then a buck.
  5. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Get the correct size and material it will work and last a long time.
    rthomas771 likes this.
