Gas tank sending unit
Discussion in 'General Maverick/Comet' started by Gene Fiore, Nov 19, 2011.
  1. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    I want to remove and inspect the sending unit from my tank. Once I drain the fuel, what is the technique for removing the locking ring? I don't want to break anything.
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    They make a tool for it. But a brass punch and a hammer will do the job. Just needs to rotate a small amount.
  3. Moneymaker 1
    Panama City Florida
    Yes use brass...it won't cause a spark.
  4. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Just about all the fuel that is going to drip out is out...how much more fuel can I expect to pour out when I loosen the locking ring?
  5. mulberrycop
    mulberrycop Member
    Northeast PA
    76 2 door, 73 grabber, 76 2 door
    Depends on how much gas is in the tank. If I remember, the unit is near the top of the tank.
  6. Craig Selvey
    If you have drained all the gas...should be able to remove it with no leaks. Maybe jack up that side of the car, tilting the tank, when you remove it
  7. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Ok...so I got the locking ring off but how do I remove the sending unit assembly?? Do you have to push in on it to loosen or what?
  8. Craig Selvey
    Once the ring is removed...it pulls right out. Might be a little stuck. A little persuasion with a flat screwdriver should do the trick.
  9. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Thanks Craig...that did it! The reason I am doing this is I am chasing a low fuel pressure concern. I am running an oem mechanical carter pump with a new fuel filter. Pressure is barely 4lbs at idle and barely 3lbs under load. I suspected maybe the filter inside the tank was dirty. So now for more questions:
    1) Is the filter over the sending unit supposed to be black? The filter fell apart at its' seam when I touched it.
    2) Is Autokrafters the only place I can get a new one?
    3) What should I do about the o-ring at the opening? It's really in there and wonder if I should just leave it or pry it out and get a new one?
    4) Anything I should do with the sending unit before I re-install it?
    Thanks for the help guys! :thumbs2:
  10. maverick1970
    Missouri
    The filters are the same on the Ford sending units of the era. Difference being if it is a 5/16 or 3/8 tube. If your gas gauge worked fine then nothing more to do. Go ahead and get a new gasket, they are cheap.
  11. rthomas771
    1.) Factory is black...replacements are white
    2.) No...any Mustang shop should have them
    3.) Get a new one
    4.) I never been able to install the sender with the tank in the car without it leaking. Take the tank out and stand the tank on its end so you can get to it easier. A thin coat of axle grease on the gasket will keep the gasket from sliding around. Make sure to clock the sending unit or the gauge won't read correctly
  12. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    What does this mean? :huh:
  13. rthomas771
    Have the sender squire with the tank. I you have it cocked before or after 12 O'clock then it won't read correct. If it’s upside down it will read empty with a full tank and full with a empty tank
  14. Craig Selvey
    Sender should have tabs on it so it only goes in one way. It is "self-clocking". :D
  15. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Ok, that's what I thought....whew!
