Gas Tanks
Discussion in 'Parts Interchange' started by Tom Laskowski, Sep 14, 2005.
  1. Tom Laskowski
    Tom Laskowski Member
    Bay Area,California
    (3) 71's,two V-8's and one 200 cid
    Anyone know for a fact if a 1976 gas tank will fit a 1971 , and if so is the filler neck the same?
  2. Mavaholic
    Yes, it will fit. You will need the 76 straps and the tank might rub along the bottom of the valance panel. You can easily pull on the bottom of valance to put a slight bow in it to clear the tank. Nobody will ever notice it. I did it to my 77 when I converted to small bumpers.
  3. Mavaholic
    Oh and, the filler neck is the same
  4. Tom Laskowski
    Bay Area,California
    Thanks, my tank has a leak,and they sell new 76 tanks and straps,there $125.00 plus $19.95 for the straps, don't like the idea of pulling out the rear valance I'll check to see what it cost to repair mine.Also is the fuel sender differant ?
  5. 71gold
    when i put the '77 tanks in my '71/'73 i didn't have to do anything to the valance...what Dennis is talking about is it will touch the tank... NOT be to where you will have to bend the valance to clear...frank...:bouncy:
    where did you find the tank for $125 ?:huh:
  6. Mavaholic
    This is true, it does just touch. However, due to normal vibrations, I prefer to slightly bend it out so it is not touching at all. JMO
  7. PART-TIME
    PART-TIME Member
    Ocoee, Fl.
    Grabber Clone
    The filler neck in my 77 is off set from the center of the tank. Are'nt the early 70 tank filler necks centered? A 76 tank might fit into your early 70 Mav. but would'nt you have to reroute the filler tube?
    Ken
  8. Tom Laskowski
    Bay Area,California
    Hang on and I'll find the site for the $125.00 tanks
  9. Mavaholic
    All 71-77 tanks are the same other than capacity.
  10. Tom Laskowski
    Bay Area,California
  11. PART-TIME
    PART-TIME Member
    Ocoee, Fl.
    Grabber Clone
    Thanks Tom. Good tank site. Now, if they would make one with a centered filler neck so I won't have to run my exhaust through the leaf springs. I guess I'm gonna break down and follow Dennis's lead and modify the Mustang tank to fit.
  12. Tom Laskowski
    Bay Area,California
    Welded up the tank today, pressure tested it and all is fine, will put it back up in a couple of days just before I leave for memphis
