Is there a sealer that can stand gasoline? I finally found where that whistling sound that I thought came from my carb comes from. The carb is a spread bore and there is a spacer between it and the manifold, there is vacuum leak between the manifold and the spacer. The best thing would be to get a new square bore carb and throw away the spacer, but that will have to wait.
aerospace sealant.. B1/2 or B2 i see you are in iceland.. if you are near the military bases.. check there if you know anyone in the military, ask them for it... we used it on fuel cells on aircraft.. it works AWESOME other than that.. i dont know what to use from the auto parts stores
The gas tank renew kit called "KREAM" , works great. It withstands all gasolines,racing fuel,alcohol too. When I worked at a Ford dealership...We had a 2 part epoxy called "CREST". Worked better than JB WELD.....sealed the tank while gas was still leaking......Great stuff!
oh.. i thought you needed to seal a leak or something.. yeah.. go with what hotrod said to seal the inside of the tank
Unfortunetly the base was shut down last autumn and everything was moved to east europe I think. This is just a vacuum leak if I can't find a sealer I will try to make a new gasket from thicker material.
The gasket is not available here, so I bought thick gasket material and made it my self. And the wisthle has stopped
Wow. weird parts store that doesnt carry those. They are usually hidden however with dust on them. lol Glad you got your problem fixed.
