Gauge cluster housing
Discussion in 'Technical' started by alex3, Mar 4, 2012.
  1. alex3
    alex3 Member
    1970 maverick
    Please help quick! The housing that holds the gauges, I took out the two screws in the recessed part and I don't know where to go from here I was scared to pull because I didnt want to break anything
  2. bluezjeep
    bluezjeep Member
    Colorado
    1971 Maverick 302 C4
    Take the ashtray out and reach in behind the cluster to disconnect the speedometer cable
  3. alex3
    alex3 Member
    1970 maverick
    So I took off the ash try door and un screwed all of the screws, and now how do I get the stray out, it's to big to fit through?
  4. alex3
    alex3 Member
    1970 maverick
    Nobody? Really?
  5. Dave B
    It'll come out, if you push it in, and spin it around, It's been awhile, but I've done it.
    You don't need to take it out to get the speedo cable off, but it does make it easier.
  6. Craig Selvey
    No need to take out the ash tray, just reach up under the dash and feel your way up the speedometer cable. There is a white clip where it plugs into the back of the speedometer. You have to squeeze that white clip and pull the cable out.
  7. bluezjeep
    bluezjeep Member
    Colorado
    Craig is the man and he is right on. You don't have to take the ashtray out but I found it to be a lot easier. That and I don't like to stand on my head to get under the dash. Good luck
  8. Craig Selvey
    What can I say, I am small, limber, and nimble. :D
  9. maverick75
    I usually reach in through the radio hole. My huge arm fits in there :D
  10. mercgt73
    In my family, we call it "Sleek and Racy".
  11. jmgford
    jmgford Member
    Iowa
    Don't they make a blue pill for that?
  12. alex70mav
    alex70mav Member
    huntington beach
    1970 ford maverick 302
    hahahahahahahahahahahahahahahahahahahahahahahahahahahahaha:rofl2:
  13. beng19999
    beng19999 Member
    longueuil
    comet 1976
    i took mine out from under the dash and the white clip was so dry that it broke but i put it back after with no clip and it never fell down
  14. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    The clip on mine broke too but the cable wouldn't stay in with the broken clip. I pulled the cable up thru the floor some and put a small hose clamp around it to hold it there. Now I can slip the cable in and out of the speedometer head with ease and the cable stays in the head.
  15. mojo
    I remove mine by removing the cable frm the trans first. I then pull the cable a few inches into the car, frm there I can get the cluster out far enouugh to reach the clip "my car is flr shifter", so not hampered by the shift lever. I assume this won't work for non-flr-shifters.
