gauge cluster removal
Discussion in 'Technical' started by J.Hope, Dec 1, 2003.
  1. J.Hope
    J.Hope Member
    Walker La.
    1976 Maverick
    I'm finally trying to fix my a/c heater controls from those parts I got from speedy and can't get the gauge cluster out. Seems like you have to drop the steering wheel and pull the speedometer out if I could figure out how the thing is connected. I seem to remember there being some type of clip back there but cant get it out far enough to see. Anyone have any suggestions. I don't want to break anything else while trying to fix something if you know what I mean.
  2. 71gold
    there is hope:D :D i took mine out the other day and put the new 2825 bulbs in. i had a speedo cable clamp under the car i had to take loose to get enough slack in the cable. i took the clamp loose and the cable loose from the tranny. i was under there so i made sure i had enough slack...frank...:bananaman :bananaman L.T.N.G.
  3. Grabber75
    Grabber75 Member
    Mount Vernon, Ohio
    1975 Maverick Grabber
    you know you can remove the clip on the back of the speedometer faster right?..........everyone makes the mistake that you have to pry on the clip to get it out....totally not true all you hyave to do is push on the tab and it will come loose....
    and yes you have to pull out the cluster to get to your controls to remove them...you also have to pull the knobs of the controls too
    works best if you wrap black tape on a pair of pliers so you can grab them lenthwise and pull them........if you need any parts let me know i have a complete air condiotioning system from a 72 comet
  4. courier11sec
    courier11sec Member
    Tucson, AZ
    Read the thread called white face gauge tech article.
    I went into some detail on how to get it out in there.
  5. MavMark
    MavMark Mega Modifier
    Detroit Area, Michigan
  6. J.Hope
    J.Hope Member
    Walker La.
    1976 Maverick
    Thanks for all the help, what I thought was going to take all day only lasted about an hour. I replaced the a/c heater controls and everything started working like they were supposed too? Still can't seem to get the heater to blow hot, all I get is warm. I checked the vaccum valve under the hood and it appears to opening ok I guess I'm missing something. Any Ideas?
  7. courier11sec
    courier11sec Member
    Tucson, AZ
    thermostat temp?
    how hot does the car run?
  8. J.Hope
    J.Hope Member
    Walker La.
    1976 Maverick
    I would guess somewhere between 130 and 150. When I put the new motor in we install new sun gauges. It never gets much over the 130 mark
  9. courier11sec
    courier11sec Member
    Tucson, AZ
    Bingo.
    That's pretty cold.
    If you put in a bit higher temp thermostat and got it to run around 180-190 your heater will work better.
    My car usually hovers around 180 unless I'm in traffic or really stepped into it and the heater works great.
