Gauge light problem
Discussion in 'Technical' started by 71_Maverick, Oct 22, 2008.
  1. 71_Maverick
    71_Maverick Member
    michigan
    so im changing the light bulbs in my gauge cluster. i lost one of the light bulb retainers, so i will have to go get another but my problem is when i plug in the cluster only 4 lights come on. 2 on the speedo and 2 on the other side and the bulbs are good i have switched them out and they work in that spot also. ive also tried 180 the bulbs with no change.
  2. PART-TIME
    PART-TIME Member
    Ocoee, Fl.
    Grabber Clone
    Gonna need a more detailed description. Are you sure the socket your trying to light is supposed to be lit. Could it be a blinker indicator socket?
    Ken
  3. 71_Maverick
    71_Maverick Member
    michigan
    i think i found it out. i had a wire pulled out of the harness.
