gear ratio/ axel spline?
Discussion in 'General Maverick/Comet' started by wjtkb, Apr 13, 2012.
  1. wjtkb
    wjtkb Member
    keystone heights fl
    maverick, 94 toyota pick-up, 94 honda accord
    so im getting my 9in in the mail here soon, i know i have the close ratio 4 speed top loader, im going to be putting in a 347, this is going to mainly be for the street but i am planing on racing it every once in a while, the housing is coming with 28 spline axels i wasnt sure if i should just get some 31 splines or exactly, any input would be appreciated thanks
  2. John Holden
    John Holden Member
    NJ
    When you say you're getting your 9" in the mail what does that mean, the whole thing with center section? You can't just swap the 31sp for the 28sp axles without changing the whole carrier(posi unit if you have one). The side gears are specific to the axle size/spline count.
  3. wjtkb
    wjtkb Member
    keystone heights fl
    its basically just the housing, it has not third member (pumpkin) its just the housing with the old axels they had for it they kept the 3rd mem.
  4. Acornridgeman
    Wisconsin
    Yes, you will need to match axles to whatever pumpkin you buy.
    As for 28 spline strength, I trust them. I had 4:10 gears with 28 spline axles in a vintage Bronco that I used to do some really hard off-roading in. Broke and twisted several driveshafts but never broke an axle.
    (y)
  5. wjtkb
    wjtkb Member
    keystone heights fl
    yeah it comes with the 28 spline axels, and the drum brakes, i hear a trip to the local u pull it is coming up for some disc rear brakes here soon haa
  6. wjtkb
    wjtkb Member
    keystone heights fl
  7. John Holden
    John Holden Member
    NJ
    I've broken enough 28 spline axles to know that I'll never run them again unless I know I'm NEVER going to use a sticky tire or race at the drag strip.
  8. wjtkb
    wjtkb Member
    keystone heights fl
    im appreciating all this info, please keep it coming
  9. John Holden
    John Holden Member
    NJ
    Plus now would be the time (before you buy a center section) to consider changing to 31sp axles.
  10. wjtkb
    wjtkb Member
    keystone heights fl
    im thinking about it, i figured i didnt really need the third member yet due to no know what gear ration i needed yet so i figured id grab it up before i had to start hunting down another direct bolt it unit
  11. Acornridgeman
    Wisconsin
    John has a good point about drag racing and sticky tires. My application was off roading so you naturally get a lot of tire slip.
  12. wjtkb
    wjtkb Member
    keystone heights fl
    i just looking on currie enterprises website its not to much to upgrade them any ways
    maybe ill make something out of the other axles maybe get a rim or two and set up something for a bench grinder or something
  13. John Holden
    John Holden Member
    NJ
    Currie is probably one of the most expensive places to get a third member.
  14. wjtkb
    wjtkb Member
    keystone heights fl
    yeah i just looking at some of the prices, the axles are only $320 but im still looking around
  15. John Holden
    John Holden Member
    NJ
    Try moser for the axles.
