Gear Ratio Preferences?
Discussion in 'Transmissions' started by Mr Nick, Sep 27, 2014.
  1. Mr Nick
    Mr Nick One with many questions
    Grapevine, Texas
    1971 Four-Door Maverick, 1962 Cadillac Sedan deVille (soon)
    Hello all,
    Running a '71 with the 250. Will be bumping up to a V8 in a good while but for right now I'm doing a rear end 4 to 5 lug swap. Was just curious as to who still runs the 8" rear and what ratio they've used with no issues. I'm looking at a 3.25 to a 3.55 but have no idea what to run exactly
  2. Bryant
    i would run 3.25s for average street use. you will be able to go freeway speeds and not be spinning the motor to the moon and have some good get up and go from a stop.
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I agree with this. ^
  4. 71gold
    with the 250 I would run the gear in the rear end you get in the 8" if it's a stock gear...2:79-3:00.
    when you get the V8, change it to the gear for the motor/transmission you run in it.
    I'm running an 8"...
  5. Mavit
    Mavit Member
    Prince george bc
    two muatangs ansd one comet
    When you change the engine to a V8 you may want to look at a Over drive transmission that way you can have the acceleration of a set of low gears with a cruse rpm of high gears! I did this with my Maverick and because it works better I drive my car more! With 4.11 gears I run lower RPM at 60 MPH than I did with stock 2.78 gears and the C4
    transmission!
    Crazy Larry likes this.
  6. Chief1010
    Chief1010 Member
    Kentucky
    72 Maverick 306, 351W heads.. 75 Maverick ( parts car )... 71 Maverick ( in storage ).. 71 Torino 500 ,306, TCI Trans, Detroit Locker..
    Everybody is telling me to change to a 9 inch.. How much can the 8 inch hold up to ?? got a 302 30 over 351W heads, and a 515 lift cam.. Do I need a 9 inch ??
  7. velvetguru
    velvetguru Member
    Owasso, OK
    1975 Mercury Comet, 1965 Ford Mustang, 1962 Lark Daytona
    If you're running an automatic with rear axle gears between 2.79 to 4.11 the 8" will hold up fine with that engine. Now if you're going to 4.11's or lower with a stick and do alot of hard launching you might want to look at a 9"
  8. Chief1010
    Chief1010 Member
    Kentucky
    Mine is strictly for the street. Maybe hit a few car shows, and something for me and the old lady to go out on weekend and tear up some country roads.. That is good news that the 9 inch is an option and not a half to.. Thanks velvetguru.
  9. mojo
    302 for street use -- 9" not necessary..
  10. Mavit
    Mavit Member
    Prince george bc
    This is true if the 8 " is not abused it can last a long time, If slicks are entered into the equation the 8" will be short lived
  11. 71gold
    ran 8" w/3:55s ,Detroit locker, Caltracs and slicks...so far no problem...(street car)
  12. rthomas771
    The 8" is tougher than a lot of people give credit...not saying you can't break one. With street tires, the tire will be break traction before anything else breaks.
  13. Mavit
    Mavit Member
    Prince george bc
    In my 302 Maverick with high stall and slicks I got 75 low 13.00 passes down the Quarter mile with my 8' before it Broke the spider gears!
