Gears???
Discussion in 'Drag Racing' started by valleyracer, Jun 6, 2004.
  1. valleyracer
    valleyracer Member
    Ottawa Canada
    1977 Maverick Drag car 399 engine,C4 trans,9"with 4.33 gear ET 10.25 @ 128 mph
    What is the optimum gear for the 1/8 mile setup ?
    Richard:confused:
  2. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Although I'm probably not qualified to answer this, since I have never run 1/8th mile, my "guess" would be 4.56 or even lower...
  3. courier11sec
    courier11sec Member
    Tucson, AZ
    Depends on ummmm...
    everything.
  4. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    Yes, it does depend on alot........but I know Valleyracer is aware of this.
    So I will add that with a basically bone stock motor, open headers, C4 and slicks(at 2850 pds). I ran a 4.56 gear. Shifted at 6,600 rpm and went through the traps at 6,300 rpm. Best was 7.71@84.
    With my current set-up, New, not so stock motor, headers, C4 slicks at 2,800 pds. and 4.86 gears, shift at 6,800 go through the traps at 6,800. Best is 6.55@105.
    Both was done on Footbrake, no transbrake here......old school!
    I would say looking at your set-up and times in the 1/4 mile. if you are trans braking, probably the 4.56, if you are footbraking probably the 4.86......again JMO.
  5. valleyracer
    valleyracer Member
    Ottawa Canada
    Good Info
    Thanks for the good info , I am footbraking and was thinking in the 5.13 to 5.38 range ? New 306 will have 7000 RPM limit and H-beam rods , light weight pistons and lots of carb ! Any other suggestions ?
    Richard Miller(y)
  6. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    How about your tire size?
    I know guys running those gears but they have some pretty big meat under their car.
    I was doing those #'s with a 28x9
  7. valleyracer
    valleyracer Member
    Ottawa Canada
    Still 28x9 slicks and C4 4200 stahl converter , sounds almost the same as yours? Do you hit 3rd gear just before the 1/8th mile?
    Richard
  8. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    With the old 302 and 4.56's I was in 3rd for just a second....not very long, but I think your motor will rev. alot faster than my 302 did.
    How much does your car weigh and what gears are you running now in the 1/4?
  9. valleyracer
    valleyracer Member
    Ottawa Canada
    The car wiegh's 3000 lbs with driver approx and 4.56 gear shifting at 6500 rpm
    going through the Quarter at 7000 rpm
    Richard
  10. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    I was always told that whatever you shift at, thats where you want to be in top gear when you go through the traps. But going by your #'s a 5 something gear might work out fine for you. I did switch to the 4.86's(from the 4.56) when I had the old 302 in it and it only changed the big end rpm by about 400-550 rpm. The is a link that I got somewhere that has a calculator for picking rear gear selection, I will find it after my morning production meeting and post it for you.
