Getting ready for paint
Discussion in 'Cosmetic' started by Dean Deeter, Apr 14, 2013.
  1. Dean Deeter
    Dean Deeter Member
    West Carrollton, Ohio
    1974 Comet GT and 1974 Maverick
    I have a 74 Maverick that we are getting ready to paint. I have a couple questions. How do you take off the side moldings,are they accessible to buy new ones? Do most people leave them off? Also the Maverick emblem on the side after the side rear window do you have to take down the headliner to get them off?
  2. rthomas771
    I tried hard not to bend the trim but it got bent. The clips are bolted on close to the ends and the ones in the middle are spring clips. The clip's mounting pins are welded to the car. I use a Dremel to cut the pins. The roof emblem can be pried off with a putty scrapper...just walk it off one end at a time
  3. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
    I don't think you can buy new molding
  4. junrai
    junrai Member
    rancho cordova ca
    I believe autokrafters has the chrome available
  5. Craig Selvey
    There are nuts on the back side of the moldings. Where there are no nuts, then the factory used plastic clips. The moldings just pry off of the plastic clips.
    Nobody makes the chrome moldings.
    Putting them back on or leaving them off is a personal decision. I would say most leave them off.
  6. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    I took mine off for paint, now that its off its not going back on. I like the without look a lot better. Had a friend from work come out and weld up the holes. Not sure if ill put the rocker chrome back on yet, will have to see when its done.
  7. Dean Deeter
    Dean Deeter Member
    Thanks for the help, Can not wait to get started,taking it to Nicholasville,Ky for it to be painted by a friend of mine who painted my Comet 17 years ago and it still looks great!!!:bananaman
