Hold On! Here's my list ARP-154-6402 Connecting Rod Bolts, High Performance Wave-Loc, 8740 Chromemoly Steel, Ford/Lincoln/Mercury,289/302,Set of 16 $56.88 $56.88 CCA-26986-16 Valve Springs, Single, 1.415 in. Outside Diameter, 280 lbs./in. Rate, 1.060 in. Coil Bind Height, Set of 16 $219.95 $219.95 CCA-3120 Timing Chain and Gear Set, Hi-Tech, Double Roller, Steel Sprockets, Ford, Small Block, Set $49.95 $49.95 CCA-611-16 Valve Locks, Machined, Hardened Steel, 10 Degree, 1-Groove, 11/32 in. Valve Stem, Set of 16 $22.88 $22.88 CCA-795-16 Valve Spring Retainers, Steel, 10 Degree, 1.095 in. Outside Diameter, .640 in. Inside Diameter, Set of 16 $53.95 $53.95 CCA-8931-16 Lifters, Hydraulic Roller, Vertical Link Bar, Ford, 221-302/351C/351M/351W/400, Set of 16 $592.99 $592.99 EDL-60359 Cylinder Head, Performer, Aluminum, Assembled, 60cc Chamber, 170cc Intake Runner, Ford, 289/302/351W, Each $621.50 $1,243.00 LUN-61002LK Cam and Lifters, Hydraulic Flat Tappet, Advertised Duration 262/268, Lift .499/.522, Ford, 289/302, Kit $195.95 $195.95 SUM-900015 Rod Bolt Stretch Gauge, Steel, Dial Indicator, Adjustable Length, Right/Left Configurations, Kit $6 I'm not too worried about the cam and the timing chain, I may still change my mind, so if you don't have room...
Dave, man.... lol... with the shipping being free and handling being 10.95 or something, it might pay to buy straight from summit. or you could always just hand over the money, i'm sure it would still get spent in summit.
went by Jeffs house and picked him up, went and ...ATE...came back by Summit. after doing a lot of lookie-see, i picked out a set of valve covers i have been wanting. Jimmy stopped by for some parts and gave Jeff a ride home..:Handshake "a large time was had by all". P.S.: Dave, do you have a new address for me to send these parts to or do you want me to send them to the same one i sent the others to? ......
Aren't you the same guy that sent me that email about all of those "many million dollards" that you needed my help in getting out of your country?
this must be the ...billing address and the other one must be the ...ship to address? DFF...:Handshake
this is a pic. of me..."lookie-seeing". they had 10 sets (a case) of the valve covers and i went through all of them to see if any of them were purty-er than the others... the 3rd. set looked best... ......
Whats wrong with the Maverick ones you've been using?? Have they become a collectors item?? I hope you didn't get those "Ford Racing" ones.....
