gonna need some help....
Discussion in 'Technical' started by Thrashin302, Sep 24, 2011.
  1. Thrashin302
    Thrashin302 Member
    South Dakota
    Does anyone know how to replace the coil springs and front struts ona 70 mav. I have spring compressor and figured i could take the whole works out in one piece but i dont think it works like that with these cars. any help or if there is a link to how to someone could show i would appericiate it.
  2. 71gold
    no front struts...
    removing the coil springs is a dangerous job for a beginner.
    with that being said, what spring compressor do you have?
    http://mmb.maverick.to/showthread.php?t=72393&highlight=coil+spring+removal
    ...Frank...
  3. b_ryce70Mav
    b_ryce70Mav Member
    Shaw AFB, SC
    The shock comes out first. Unbolt it from the upper control arm, then from the upper shock mount (in the engine bay). Then you can feed a spring compressor down the spring, compress and remove. As mentioned though, its a fairly dangerous task. There's a lot of energy compressed in that spring. I handle them like hand grenades with no pins when I pull mine.
  4. Thrashin302
    Thrashin302 Member
    South Dakota
    thanks b_ryce. Thats what i needed, i made it out harder than it was. for anyone attempting this project when the spring is compressed in the compressor dont hit it with a hammer to try and force in position, my brother almost lost his hand twice doing that, just unscrew it if it dont fit and compress it differant.
  5. lynhrt210
    lynhrt210 Member
    somewhere
    1974 ford maverick
    Yup watch yourself,you can lose something if your not careful
  6. bmcdaniel
    bmcdaniel Senile Member
    I drop a heavy chain down through the shock tower and bolt the ends together in the engine bay to secure the spring, just in case...
