Good fitting Driveshaft Safety Loop
Discussion in 'Technical' started by tbirdz12, Nov 20, 2006.
  1. tbirdz12
    tbirdz12 Member
    Sun Lakes, Az
    69.5 Mav
    Im looking for a driveshaft safety loop that bolts up nice.
    Any leads appreciated.
    Thanks
    Tim
  2. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    :rofl2: good luck
    i think all of them require some work, i bought a summit uni. loop and its a PITA it does fit at all, going to have to cut it down
  3. ShadowMaster
    ShadowMaster The Bad Guy
    The ShadowLands
    1969 1/2 Maverick
    If it's a true "bolt on device" it doesn't work.
  4. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    What do you mean by that? :16suspect
  5. eddie1975
    Martinsburg, WV
    sold
    I think what he means is that if its a "bolt on" loop it wont work but we already knew that:slap:
  6. tbirdz12
    tbirdz12 Member
    Sun Lakes, Az
    69.5 Mav
    So are ya saying just build one from scratch?
  7. eddie1975
    Martinsburg, WV
    sold
    prolly be less of a hassle , they sell custom loops from summit and jegs, which you cut and weld to fit
  8. Cleaver
    Cleaver Member
    MD
    Chel
    Loops are easy parts to make that the most novice builder can handle. The best fitting loops start out as a 1" wide x 1/4" thick piece of flat bar stock and are cold bent around a small forked tree. Not trying to be a smartie pants - just improvise. Only tools required are a hand drill and a hacksaw - which you will need to have to "tweek" any "bolt-on" loop.
    Cleaver
  9. cometguy
    cometguy Member
    Schomberg, Ontario, Canada
    72 Comet GT 302/AOD, 1972 Mustang NHRA Stock Eliminator 351C
    There's really nothing wrong with a Lakewood #18000 universal loop. I have one on my car; (it was already installed when I bought it). It's not pretty, but it does the job and passes tech.(y)
  10. eddie1975
    Martinsburg, WV
    sold
    yeah you prolly dont know the trouble they went though to make it fit;)
    ask MaverickMatt
  11. Grabber5.0
    Kansas City, MO
    71 Grabber
    Aw, it weren't nothin a chop saw and a drill press couldn't cure. :D
