gotta imagine this is hard to find...
Discussion in 'Cosmetic' started by MaverickLVR, Apr 3, 2011.
  1. MaverickLVR
    MaverickLVR takes longer then you think...
    Grand Rapids, Michigan
    1976 Maverick Stallion, 1967 Olds Delmont convertible, 1999 Harley FatBoy
  2. 71gold
  3. mightymav72
    mightymav72 Member
    Sevierville,Tn
    1972 Ford Maverick with a 351 Windsor
    All the switches I've had were missing the toggle. I do not know what one really looks like.:hmmm:
  4. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
    Most of the ones that are still in cars have the plastic piece that extends the lever missing. I have 3 switches and only one of them have the black plastic on it, the others are broken off. I am going to see if I can find a donor switch that I can repair the others with.
  5. 19Grabber72
    19Grabber72 Member
    Cedar Falls, Iowa
    1972 Maverick 2 Door Sport Sedan Grabber
    FYI My car still has her plastic lever thank goodness. I think the new toggle plastic arms are a bit larger. I have seen some open the hole up in the bottom of this piece and then push the toggle arm down into it. Looks like it belongs anyway from the ones I have seen done.
  6. Fordmaster169
    Coos Bay, Oregon
    I was thinking more on the line of finding a toggle switch that has about the same style lever on it. Then I will cut it off and drill a hole in it, then use some epoxy to glue it to the original switch to make it look all original.
  7. 19Grabber72
    19Grabber72 Member
    Cedar Falls, Iowa
    Exactly, that is what I mean with the above. Have fun and post a pic and some details of what sort of toggle you use for everyone. :thumbs2:
  8. maverickfever
    maverickfever maverickfever
    Winnsboro SC
    26 Mavs and Comets
    Maybe you could find some black shrink seal in the form of a cap(like you use on electrical) and shrink it onto the end of the toggle switch arm.Just a thought.
  9. Earl Branham
    Lugoff, SC
    I have a switch and cover, but I think the switch is bad. Cover is good, though. If you need the cover, drop me a pm.
