Grabber Spoiler Install 1973 Maverick
Discussion in 'Technical' started by mrskydog, Feb 16, 2010.
  1. mrskydog
    Muskegon MI
    I have a 73 Maverick I have the Center Spoiler and both , corner pieces. a total of 3 parts. Do I need any additional parts to complete Spoiler up grade? I have seen were some have posted that a total of 5 parts...Center, ends, and 2 small fillers at end caps? True or not for a 73 application. Thanks Kirk
  2. scooper77515
    Should have all 5 for a small bumper setup. you could probably make it work without the 2 little pieces.
  3. yellow75
    Tillamook Oregon
    Use what you have Kirk, the filler pieces on the 73 are completely different
  4. scooper77515
    The 73 had the same small bumper. how different was the 4th and 5th pieces on a 73?
  5. Matterick
    Matterick Matt Somerville
    Lake Stevens WA
    Big difference! because the back bumper on a 73 sticks out (y)
    heres some pics to compare [/ATTACH]
  6. yellow75
    Tillamook Oregon
    Bumper brackets on the 73 are longer and push the bumper out a little further than 72-70, the filler piece under the bumper on a 73 is a rubber piece about the size of you fist or bigger
  7. scooper77515
    Hmmmm. Never seen that.
    Learn something new every day.
  8. Craig Selvey
    If you are keeping the 1973 bumper mounts.....then you have all the pieces you need. If you are switching to the 1972 bumper mounts, you will need the two lower quarter extensions.
  9. mrskydog
    Muskegon MI
    Thanks for all the input ,it sounds like I have everything I need. Time to paint and install....:thumbs2:
  10. justin has a 74
    kentucky
    So which one looks better????
