Granada Disc Brakes
Discussion in 'Technical' started by Mavman94, Dec 22, 2014.
  1. Mavman94
    Mavman94 Member
    72 Ford Maverick Grabber
    i have a 72 Grabber I want discs on but I cant find any. my uncle found some on a Granada. will these work?
  2. mojo
    Granada brakes will work; that's what a lot of folks use in lieu of aftermarket setups.
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    The Granada disc brakes are the same as the Maverick Disc brakes. Put 'em on.
  4. Mavman94
    Mavman94 Member
    i will once I get the right master cylinder haha
  5. mav1970
    Any early Granada or Monarch will work - The later Granada had the strut front suspension and those brakes are different
  6. injectedmav
    injectedmav Member
    Georgia
    My first conversion back in the late 80's was Granada. 74-75 Maverick manual disc brake master cyl will work and a lot of supply houses still carry them. You might have to order it though
  7. 73curtis
    73curtis Member
    ohio
    I just bought a 72 with brakes already converted non power , the brake pedal sits way to high , any thoughts
  8. Moneymaker 1
    Panama City Florida
    Master cylinder push rod is too long.
    Crazy Larry likes this.
  9. Krazy Comet
    Yup, they come in varying lengths...
  10. rthomas771
    The Maverick/Comet pushrod is this long
    Paul Masson likes this.
  11. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Get an adjustable pushrod, or get a pushrod from a '70-'73 drum-brake master cylinder.
    Don't forget to replace the retainer clip.
  12. 73curtis
    73curtis Member
    ohio
    thank you, is it hard to change?
  13. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Well, you have to use the proper technique. To get the old rod out, you'll have to take the M/C out of the car and mount it in a vice. Using a pickle-fork or a large adjustable ("Crescent") wrench and a hammer, knock out the old rod, which will break the clip holding it in. The replacement rod with a new clip will pop right in and snap into place.
  14. 73curtis
    73curtis Member
    ohio
    is it at all possible to remove it while it is in the car, I hate to have to re bleed the brakes they work great right now
  15. 73curtis
    73curtis Member
    ohio
    when you shorten the rod does it effect the brake light switch
