grease fitting?
Discussion in 'Technical' started by Blue Brick, Jan 12, 2014.
  1. Blue Brick
    Blue Brick Member
  2. Krazy Comet
    There is a opening in the upper control arn to access fitting, that fases either rear or forward depending on R or L side... Problem is not all are greasable...
  3. blugene
    It says comes with the fitting but I don't see any where to put it..
  4. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    It goes in a weird place, on the bottom side of the flat mounting plate, not on the ball joint cap as you think it would. The one I replaced on my 74 was like that, I like to never have figured it out myself. It forces grease through a channel in the plate apparently up into the ball joint. I always had the problem of mine coming out with the grease gun nipple. It's a drive in fitting, not a screw in like it should be.
  5. injectedmav
    injectedmav Member
    Georgia
    That is the same a the McQuay/Norris joint I used on the ProMotorsports kit with the grease fitting on the bottom plate. My grease fitting screwed in that extra hole in the plate and is easier to grease than the Moog type with the fitting in the top. Good to know since NAPA no longer carries that type joint.
  6. Blue Brick
    Blue Brick Member
    Thanks!!!!
