Grille
Discussion in 'Technical' started by maverick600, Jan 4, 2020.
  1. maverick600
    maverick600 Member
    San Angelo, Texas
    What did they use to mount the grille in these cars? I could get some nuts and bolts but would rather use fasteners or what have you. 15781741918456985121961282577297.jpg
  2. Acornridgeman
    Wisconsin
    On the bottom - there are 2 pins that go into a rubber grommet. The pins often break off but are pretty easy to repair. On the top the 2 outer edges are held in place with a plastic push rivet. Kinda like a big plastic pop rivet. The 2 center locations by the hood latch support are phillips head screws that go into some stamped u-nuts.
    The right grommets are available from Melvins or AK - the plastic pop / push rivet and the screws with u-nuts can be found at auto stores like O'Riellys
    maverick600 likes this.
  3. maverick600
    maverick600 Member
    San Angelo, Texas
    Thanks for that. I went to Ace hardware looking at spring clips but they didn't have the ones that are the same size as what I need to work. I'll check out Melvins for the rubber grommets cause mine are missing. The plastic push rivets should be easy to obtain. Thanks again
  4. Acornridgeman
    Wisconsin
    From Melvin's catalog - they call them grille clips item #AMK139
    And the grommets the pins go into - item #383333S
    The u-nuts and screws can be found at the auto parts store.
    The screws formal name is: round washer head tapping screw
    mvw66gt, 71gold and maverick600 like this.
  5. Craig Selvey
    I have all of those items....used....if you want them. Email me DIRECTLY (see below) if I can help.
    BBMS18 likes this.
