grind flakes + pearl paint = rust specs.. HELP!
Discussion in 'Cosmetic' started by 510madmav, Sep 7, 2009.
  1. 510madmav
    510madmav Member
    San Francisco bay area
    1973 Maverick
    i was doing some floor pan metal work inside the car with the doors open, while grinding.. now i have a million tiny rust specs over the car, virtually over night.
    i tried waxing, some of the lighter specs come out, but the larger stay put. what can be done?
    buffing wheel?
  2. car-nut
    car-nut Glenn
    conn.
    You can try to sand and buff, but it probably won't help. All the grinding sent samll particles right into the door and pitted the paint. It may come off if you are really lucky.
    I did this once on a door glass. The welding blanket slid off and all the grinding slag hit the glass and ruined it. It actually pitted the glass and we had to replace it.
    Good luck!
  3. bradleygt
    bradleygt Member
    grand rapids michigan
    1970 maverick
    use a clay bar:Handshake
    brad:)
  4. 510madmav
    510madmav Member
    1973 Maverick
    yeah im clay baring it today.
  5. 510madmav
    510madmav Member
    1973 Maverick
    thanks guys
  6. Mavman72
    Sparks= HOT metal shavings...They literally "burn" into whatever they land on.As you have discovered.If the clay bar doesnt work...Time to color sand and compound.Good luck!!!
  7. scooper77515
    I did this to my truck, and clay bar took it all out.
    Nasty looking clay when I was done.
  8. Columbus Comet
    Columbus Comet Member
    Columbus, OH
    My white trucks get that from the brakes. Clay bar takes care of it.
  9. darren
    Product called fallout remover. Used on new cars that get this from the train transport. Works great.
  10. Acornridgeman
    Wisconsin
  11. 510madmav
    510madmav Member
    1973 Maverick
    yep, i went down to p&s this morning and picked me up a bottle of their Crystal Wash, which is an acid that eats up everything sitting in your paint. its drying on the car now, hope it works!
