Ground to body?
Discussion in 'Technical' started by CDL, Jan 11, 2015.
Thread Status:
Not open for further replies.
  1. CDL
    CDL Member
    1970 Maverick. Where is the body ground? The only spot that my negative side of the battery goes to is the engine block. But the engine block has rubber mounts. Shouldn't there be a cable directly from the negative side of the battery to the body somewhere? I don't think from battery to front fender is acceptable.
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Originally the ground cable would have gone from the negative side of the battery to the bolt on the bottom corner of the voltage regulator then a cable from there to the block.
  3. Hotrock
    Munroe Falls, Ohio
    You are right! Your negative battery cable runs from the battery to the front of the engine block. There should also be a heavy ground strap that runs from a right side bell housing bolt up to a fairly large bolt on the fire wall just above and to the right of your heater motor. The heater motor should also be grounded to the same bolt. Hope this helps.
  4. CDL
    CDL Member
    Thanks I will check that
  5. rthomas771
    I think they stopped using this ground cable. I never seen it on a Maverick. The ground bolt around the heater ground is actually a sheet metal screw. I'm thinking the only engine to ground is the alternator's ground wire
  6. Craig Selvey
    I have never seen an engine to firewall ground strap on a Maverick either.
    Crazy Larry likes this.
  7. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
    I ran one from the block to the chassis too. I think I might have used a bumper frame bold, but dont remember.
  8. Hotrock
    Munroe Falls, Ohio
    Craig,
    You are the expert! You have owned enough of the vehicles.
    I'm going by what was on my Comet when I purchased it. It had a flat, bare ground strap about 5/8ths inch wide (not fabricated looked original) leading from the bell housing bolt to the fire wall where the heater motor is grounded. I suppose someone could have added it. I replaced it due to the number of engine/transmission R&Rs I've performed. My starting system works fine with this arrangement.
  9. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    It's a uni-body car. There is no "body ground". The negative battery cable connects to the engine block, which is bolted to the frame (uni-body) and grounds the whole car. The rubber on the motor mounts do not insulate from conductivity.
    For a really good ground, I recommend a 2-gauge negative battery cable.
  10. Acornridgeman
    Wisconsin
    As was stated earlier by maverick1970 - the original negative cable grounded to the body via a tab that attached to one of the voltage regulator bolts and then continued down to the engine block. You can see the tab in this picture.
  11. rthomas771
    My 1960 Falcon is a unibody car and came from the factory with a 6-gauge body ground connected to the cylinder head-to-firewall. And yes, I was there when the car was bought new off the showroom floor.
  12. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Yes, and your Falcon is not a Maverick/Comet, which didn't have those.
  13. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    This is the type of ground cable that was on my 69.5 when I acquired it back in '83. The metal tab attaches at the lower regulator mounting hole.
  14. Acornridgeman
    Wisconsin
    Bob, did your car have the radio suppressor capacitor at the VR? Both my cars have the ground at the top hole and that suppressor at the bottom.
  15. rthomas771
    I guess you didn't read post #5
Thread Status:
