Grrrrr...Help~!
Discussion in 'Cosmetic' started by Noah W, Apr 23, 2008.
  1. Noah W
    Noah W Member
    San Diego, Ca
    1974 Ford Maverick
    Ok, so.... My mavericks orig owner decided to use silicon sealer around the front windshield instead of replacing the seal.. In doing this they basically covered 80% of the window trim in silicon as well. This stuff just won't come off . A razor works, but with the with the contour of said trim it ends up scratching. Any ideas? Should I remove the trim and use something to eat it off? If so what would be the best way to take the trim off? :huh:
  2. Dave B
    Nothing will eat it off, razor blade, screwdriver and lots of time.
  3. scooper77515
    If you can get the trim off, you might be able to use acetone on a rag and work it into the silicone. It will NOT be easy, but might loosen the silicone up a bit.
    Off the car, of course, so you don't rub the acetone through your paint.
    Otherwise, just rub on it with your fingers starting at one edge. It should peel off a bit at a time...
    Doesn't sound like a fun job, either way.:cry:
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    That stuff is hard to remove. You could always pick up a set of replacement trim, I am sure there are a number of members with extra sets they will sell.
  5. newtoford
    newtoford Member
    New Castle Delaware
    you have to remember theres probably a reason he put that silicone in there in the 1st place. what do you think is going to happen after you remove it and you get cought in the rain?
  6. Noah W
    Noah W Member
    San Diego, Ca
    1974 Ford Maverick
    Well, I am going to replace the entire window due to a large crack. Once a new seal is applied that should fix whatever leaking there is. I'm going to let a pro do that. I hear it is a B!TC#
    Any hints on a good way to remove said trim?
  7. scooper77515
    I wonder if the leak is from the cowl, and not the window, and previous owner didn't know and just sealed up the window...:huh:
    Use an "old" window installer. The new guys may not know how to install these old windows. Maverickkid lives near me, and had a "young" guy do it, and it looked like crap, sat out too far forward, and leaked worse when he was done.
  8. Mavaholic
    Try some oooo steel wool.
  9. qicvick
    qicvick Member
    ft.worth,tx
    1972 grabber
    decide you want want to keep the silicone on there and it will fall off in a week! LOL
  10. soooulpower
    Mapleton Depot, Pennsylvania
    :biglaugh: Now THATS a maverick truism!
