Guide plates?
Discussion in 'General Maverick/Comet' started by gtpictor, Sep 9, 2009.
  1. gtpictor
    gtpictor Member
    chicago
    maverick
    i had my 302 heads machined for studs for roller rockers and they instaled a push rod guide plate but the push rods are rubbing on them and getting metal shavings every where. If im not mistaken originally there were no guise plates so why would i need them now? thanks for your help.
  2. Bryant
    you need to get hardened push rods. you need to use the guide plates with the roller rockers.
  3. rthomas771
    What he said ^^
  4. gtpictor
    gtpictor Member
    chicago
    maverick
    yeah its turing out that way just wish the machine shop would have mentioned that before. thank you. It feels good to get the same answer.
  5. PaulS
    Wait!
    Are your roller rockers set up with the side rails that keep them over the valves?
    If they are you should NOT use guide plates at all, EVER!
    If the roller rockers are made without the side rails that keep them centered on the valve then the above advice is correct.
    BTW: Hardened pushrods are a good idea either way.
