H pipe interchnge
Discussion in 'Technical' started by coutangman, Aug 17, 2009.
  1. coutangman
    coutangman Member
    Charlotte, NC
    NPD sells preformed H pipes. Does anyone know which one(what year Mustang) will fit a '72 Maverick with a 302? Thanks.
    Jim
  2. Steven Harris
    Steven Harris Member
    Good Question!
    I have been wondering the same thing as my son and I are looking at putting exhaust on his car soon. Will be looking forward to hearing from someone who knows.
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    That's a tough one.
    Since our cars have unique exhaust manifolds, it's likely that none will fit.:huh:
    If you were to find a set of Mustang manifolds that fit, then you could use those and get the corresponding H-pipe.
  4. Bob Wiken
    Fayetteville, Arkansas
    ...or you could make (or have made) some for yourself. I'm sure any exhaust can do that.
  5. mean_maverick
    or if u was closer, i have 3 of them... :rolleyes:
  6. bradleygt
    bradleygt Member
    grand rapids michigan
    1970 maverick
    just run a x-pipe lots better think nascar(y)
    brad:)
  7. Bryant
    this is what i run on my car. http://www.jegs.com/i/Flowtech/387/53630/10002/-1 its a really nice kit. i think you can even get it with out the cut outs. the caps for the cut outs have plugs in them that fill the whole cut out tube so there is no flow distrubance in the pipes when the caped off. check this page out. http://www.jegs.com/c/Exhaust_Crossover-X-and-H-Style-Exhaust-Pipes/11525/10002/-1 it has lots of options for x and h pipe kits.
    when i got mine i took it to my friends muffler shop and they were impressed with it and the cost of it is less than what they would have charged to do it.
    if you just want a h pipe and you already have dual exhast then id just goto an exhast shop and ask for them to put one in. it should be pretty cheap to do.
  8. bradleygt
    bradleygt Member
    1970 maverick
    im running the jegs 3" x-pipe kit on my car
    brad:)
