handling problem
Discussion in 'General Maverick/Comet' started by hotrodford88, Apr 3, 2013.
  1. hotrodford88
    hotrodford88 73 302/aod
    jasper al
    1973 ford maverick
    hi. i have a 1973 maverick with factory power steering. while driving if i turn more than a little to the left it jerks all the way to the left. anyone have any ideas as to cause? the alignment checs right with a tape measure.
  2. Mavman72
    P.S. controll valve may be on its way out.
    Are all the front end parts tight?? Controll arm bushings (Upper arm) can make it dart to one side or the other...
  3. Stingrayiii
    Stingrayiii Member
    Las Vegas
    1973 Ford Maverick 302/auto
    Yep, control Valve.
    If you are going that far, change everything while you are at it. Makes it easier!
  4. hotrodford88
    jasper al
    1973 ford maverick
    thanks for the info. what all would i need to convert to manual steering?
  5. hotrodford88
    jasper al
    1973 ford maverick
    will steering parts from a 65-66 mustang fit?
  6. Mavman72
    No...But a manual centerlink and pitman arm for a maverick will. Only other part you may need will be an adler arm. Tie rods will switch over just fine.
  7. hotrodford88
    jasper al
    1973 ford maverick
    ok went to the junkyard today. no mavericks but there is a comet gt. will the steering parts from it work?
  8. rthomas771
    70-74 Maverick/Comet manual centerlink is different than the 75-77 manual centerlink
  9. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
  10. hotrodford88
    jasper al
    1973 ford maverick
    so the parts from a 70-74 comet will fit a 73 mav? and those adapters are to rich for me.
  11. Zooomzoomguy
    Zooomzoomguy Member
    Detroit, MI
    73 maverick, 2 door
    yes mav and comet are the same, except maverick is the better looking version
  12. rthomas771
    Yes, but power steer is different than manual steer when it comes to centerlink and pitman arm. You can't mix the parts together, got to use manual parts for manual steering and power steering parts for power steering. The idler arm will swap with either steering as long as you stay with the year as the centerlink
  13. jmgford
    jmgford Member
    Iowa
    If you were happy with the power steering, prior to this issue, why not just get a kit and rebuild the control valve? No special tools required and no more money or time involved than any of the other solutions.
