hard to shift into 4th....
Discussion in 'Transmissions' started by mashori, Jul 17, 2012.
  1. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    G-Force t5, it's hard shifting from 5th into 4th unless I go to 3rd first then it goes into 4th easily. Don't even have to fully go into 3rd, can just barely move into 3rd and that's enough for it to easily go into 4th. No problem going from 3rd to 4th either when normally upshifting.
  2. Mavman72
    Has it allways been this way Mo??? They do tend to be a bit hard to drop into 4th from 5th gear. Could be a syncro going bad also. You do have good forged shift forks in that trans right???
  3. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Just started doing it. I think the shift fork is stock.
  4. Mavman72
    Stock T-5 shift forks are a weak link. I think you have a syncro problem or a bent shift fork Mo. If you have a shifter on it that is adjustable as far as the throw and detents are concerned, you may want to see if an adjustment is in order. All things considered it may be time to take it apart again.
  5. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I'll check it out, I've been meaning to go through it once anyways before the race, thanks
  6. MSmithPDX
    MSmithPDX Member
    Portland, OR
    I would put money on a misaligned shift fork. When you push it up to 3rd you are getting it past the bad spot and freeing it up. Could be bent, or scratched, or a number of things that could foul it up. Just be glad you don't have a car with a mazda m5r2 in it. those seem to eat up shift forks (don't ask how I know.)
