head swap starts today
Discussion in 'Technical' started by justin has a 74, Feb 25, 2010.
  1. justin has a 74
    kentucky
    have my....
    springs
    heads
    head gaskets
    intake gaskets
    intake
    mega black seal
    rocker arms with screw in bolt things
    anything else?:hmmm:
    going with an aluminum color for the heads:D
  2. Ford Guy
    Ford Guy Member
    Pinnacle, NC
    1973 Grabber
    Looks to me like you got it all. I need a new set of heads for my car, too. What heads did you get? I'm guessing they're aftermarket based on the aluminum color comment.
  3. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Box to poke 16 holes in for pushrods, bolt thread lube, new thermostat, oil n filter, SHOP MANUAL, paper/pencil-make notes n checklist- thread-chaser or new bolt to clean threads, gasket scrapper n scotchbrite CLEAN RAGS! missing couple things,,, cant think right now,,, of course a 6-pack of Mt Dew! Good Luck!
  4. justin has a 74
    kentucky
    nope, e7 heads milled and 3 angle valve job, mabey i should grab some mt dew, im going to need it putting them heads on the motor.
  5. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    PS, I think 302 is like this, head gaskets marked FRONT. make sure it faces front.
  6. justin has a 74
    kentucky
    yeh, that would be bad:biglaugh:
  7. Mavman72
    Torque wrench??? Like DKstuck said...Push rods in holes in a box so they go back where they came from...DO NOT toss em in a can if your going to re-use em.
    Have fun!!!
  8. Ford Guy
    Ford Guy Member
    Pinnacle, NC
    1973 Grabber
    Cool. Im thinkin about gettin a set of E7's for my car soon too. Let us know how it goes. Good luck!
  9. justin has a 74
    kentucky
    pics pics pics! new comp springs, god i hate that spring compresser:mad:
  10. Mavman72
    Looks like a damper spring in there too...Are you running a roller cam??? if not,I would recommend braking in the cam without the damper springs in place.Put em in after cam break in. If its a roller...Ignore my recommendation...It wont be a problem. I hate thumb and index finger spring copressors too....:p
  11. justin has a 74
    kentucky
    cams already broken in, flat tappet
    pulled a head off today and that motor is sad.... it was burning antifreeze and i didnt know it, pistons and valves were completley white. My motors going to like the new heads. BTW when i bought it i was told it was a 91 H.O. motor, now i actually know what it is, an 84 mustang motor with 78 heads.... Total bs....
    cant wait to press the go pedal!
  12. Mavman72
    Do you know why it was consumeing coolant??? Determine the cause before you put it back together. While the heads are off check the cyl bores for cracks.Sometimes you can see em.Check the deck surface too for cracks between the bores. Determine if the head gaskets were installed properly last time around. Could be the heads you are replacing were the source of the coolant consuption.Look em over and scruitinize the block/bores as best you can before reassembly.Good luck!!!
  13. yellow75
    Tillamook Oregon
    I hate thumb and index finger spring compressors too....:p
    Got a good laugh out of that one
  14. justin has a 74
    kentucky
    Didnt mavericks come wth flat topped pistons? or did i dream that....:rofl:
  15. justin has a 74
    kentucky
    Looked at the head gasket and it looks like they used the old aluminum paint trick:yup: but the gaskets were in rough shape.
