Header gaskets that actually work?
Discussion in 'Technical' started by ford84stepside, Aug 14, 2011.
  1. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    I blew a header gasket on the Mav last weekend en route to a cruise in. Sounded like a log truck! I figured the paper style had lasted three years, so I had gotten my money out of them. Since it's such a job to replace the gaskets, I figured I'd go with the copper ones this time, they should last several years. I bought the Summit brand ones, USA made! I used the same ones on my 84 pickup a few years ago, and used a set of them on the 460 in the motor home with no problems, no leaks whatsoever. Problem solved, right? Wrong! First time, it leaked badly. Sounded as bad as the blown one I took off. Took it off, reversed it. Still leaking, not quite as bad. Banged the hell out of the tubes I could reach so I could get a socket on the bolts, and tightened the crap outta them. Dang thing still has a little tick to it. Not too bad with the hood down, but I can still hear it and it drives me nuts. So I guess I'll have to find another style of gasket, doesn't look like the copper ones are going to work on these Hookers. I seem to remember somebody mentioning some laminated ones that worked real good, but couldn't find anything in a search. So, anybody got a line on some good header gaskets that actually seal and will last a while? And not the paper ones. I don't want to have to do this job but one more time in the near future, and I'm gonna wait until cooler weather to do it.
  2. tody
    tody Member
    cologne, germany
    remflex all the way...
  3. Dave B
  4. maverickdragger
    maverickdragger GearHead
    Oneonta, AL
    1973 Maverick
    Mr gasket makes a crushable metal one. The work very well
  5. David74maverick
    David74maverick Member
    Arizona
    '74 maverick, '87 Celica
    I'm using the crushable aluminum ones from autozone, 6-7 years and still doing fine.
  6. Joe Dirt
    I've always used manifold gaskets on stock exhaust port heads
  7. baddad457
    Percy's "dead soft" aluminum ones. Well worth the admission price. Reuseable too.
  8. doncraft
    doncraft Member
    Monroe WA
    1970 maverick 68 Ranchero
    another vote for remflex
  9. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    What type of material are these made out of? I have never heard of them before and I am in the market for another set of header gaskets too.
  10. Resto
    Resto Benders Evil Twin
    Yuma AZ
    I would also get rid of the bolts and switch to some good Allen head bolts.
    I like the Mr. Gaskets. I put them on a 351W in my 84 Bronco with some Nickle Thorlys, and allen Head bolts,that was 14 years ago and the guy who has my old Bronco has no complaints. His daughters run the crap out of it at the Dunes down here pulluing a big travel trailer. The motor I built for it is still strong. Im thinking about buying that Bronco back from him.:)
  11. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    I have had very good luck with Fel-pro's, but as stated earlier Remflex makes a bad ass gasket.....
  12. tody
    tody Member
    cologne, germany
  13. Rick
    Rick G8I operations
    Ocala, Florida
    I've been using Permatex Ultra Copper RTV on my headers for years. It's been working real good for me, I'll never go back to gaskets.
  14. ford84stepside
    Berry Alabama
    Thanks! I'll check into those.
  15. Clintd
    Clintd Member
    Parlin NJ
    75 maverick, 89 Cougar (sleeper), 04 Superduty and a 87 Cougar
    I use manifold gaskets for a 92 ford Thunderbird with a 5.0. The ones on my cougar with MAC long tubes have been on for 5 years and most of the mileage was accumulated 1/4 mile at a time. every SBF I own and owned I've used the same gaskets. I have the same ones on my maverick with Headmen shorties and I drive that like I'm fleeing the seen.
    Also before I put the gaskets on I usually use Ultra Copper RTV on the header side to hold the gaskets on for install.
