Headers for 302 on 1970 Maverick
Discussion in 'Technical' started by rudymav52, Apr 26, 2020.
  1. rudymav52
    rudymav52 Member
    Houston Tx
    Two 1970 Mavericks
    Any tips on installing headers for a 302 1970 Maverick?
  2. 70protour
    70protour Member
    Texarkana, Tx
    1970 Ford Maverick
    I had my strut towers notched for additional clearance but it’s still tight. My mechanic is going to modify one tube for the needed clearance.
  3. 70protour
    70protour Member
    Texarkana, Tx
    1970 Ford Maverick
    You can see the additional space on the passenger side.
  4. bmcdaniel
    If they're long tubes like my Hooker 6901's I find it easier to have the motor mounts unbolted and motor jacked up so I can move it from side-to-side a little bit. Move it towards the passenger side and install the driver's side first from underneath. That way the steering box doesn't get in the way. Then push the motor towards the driver's side and install the passenger side header. Bolt down the motor.
  5. bmcdaniel
    My shock towers are notched, too, but that doesn't help with header clearance. The headers sit lower than that. The notches along with modified braces definitely help with changing spark plugs, though.
  6. yellow75
    Tillamook Oregon
    When jacking up the motor make sure to put a block between oil pan and jack so you do not dent it . I have been lucky with the three sets that I have installed and only unbolted the drivers side. Car has to have the front jacked way up on bolt sides and on jack stands for safety to be able to turn the header enough to get it to go in. I always take the spark plugs out so they are not an issue
    Philgrau86 likes this.
